Tractor Talk Discussion Forum
Thermostat for 1958 HI 240 Utility
Pibou
10-21-2004 19:17:46
I had to change the top hose on the radiator of my 1958 International 240 utility tractor and found the thermostat laying inside the hose next to the radiator opening. I decided to test it in some boiling water. It opened but did not close. I figured I should get a new one , just to be sure.Don't know how long it may have moved there.
I would like to know if I can find a suitable replacement from a car dealer or part store? What make, year and model may be used as replacement, if it is at all possible. What working temperature should I be looking for? I'm also in the process of changing the temp gauge and sensor as it is not working anymore. What is the thread size for the sensor?
Thanks in advance for any help.
Jrry
10-22-2004 07:18:00
 Re: Thermostat for 1958 HI 240 Utility in reply to Pibou, 10-21-2004 19:17:46
I replaced the temp guage in my 240 utility. It is standard size. I believe I bought mine at Harbor Freight.
Leland
10-22-2004 06:12:49
Just go to napa or car quest or your IH dealer they have the right one so don't worry about temp. but with out seeing your old sensor it's hard to tell. Napa has some nice replacment temp gauges that come with adaptors so don't worry be happy and you may want to look at thermostat housing if stat was in hose is it rotted out or was wrong stst installed as far as temp a 180 should work just fine.
