Tractor Talk Discussion Forum
Case 300 sputters under a load once-in-a-while
karl lasse
10-21-2004 19:16:22
I have a case 300 (1956).
Once-in-a-while it sputters under a good load. All I have to do is push the clutch in and pull the choke a little and it comes back and has good power. I don't think I have a vapor lock problem. Sometimes this happens just minutes after startup. The carb has been rebuilt with new gaskets and etc.
The engine runs very well other than this problem.
Any suggestions would be appreciated.
-karl
Barneveld WI
Coloken
10-22-2004 07:12:35
 Re: Case 300 sputters under a load once-in-a-while in reply to karl lasse, 10-21-2004 19:16:22
Try setting the carburator mixture a little bit richer. The gas may not be flowing into the carb fast enough, check the filters or the float valve orfise (sp?)or height. Slight posibility that the spark is weak or the plugs are wrong heat range.
