Tractor Talk Discussion Forum
Ford plow
Shank
10-21-2004 06:09:39
Will A two bottom 12 inch ford plow with A 3 pt hitch,fit on A case vac with A 3 pt eagle hitch?
Thank`s in advance.
Chuck MA
10-21-2004 18:45:40
 Re: Ford plow in reply to Shank, 10-21-2004 06:09:39
I use a Massey 3 point hitch 2 bottom plow on a case 300 eagle hitch and it hooks up with out any modification.
Jim.UT
10-21-2004 11:02:55
The Ford plow will be designed for a standard ASAE category 1 three point hitch. I'm not a Case expert, but I believe reading somewhere that the Eagle hitch was a proprietary Case system with different size pins. You may have to do some modificaton to mate the two.
To get a more authoritative answer you might try posting this question on the Implement Alley forum on this site.
Ol Chief
10-21-2004 20:09:25
 Re: Ford plow in reply to Jim.UT, 10-21-2004 11:02:55
Yes the ford plow will fit your Eagle Hitch tractor.However the Eagle hitch has rigid draft arms and will not allow any wiggle to your implement such as an standard three point will.Case overcame this situation by building a swivel device into the cross drawbar. This did or does allow a limited amount amount of wiggle to the plow.I can't tell you how the rigid plow will work because I have only used Case plows with Eagle Hitch.
