Tractor Talk Discussion Forum
WHICH WORTHINTON TRACTOR DO I HAVE ???
BOB WOOD
10-20-2004 19:27:19
HELLO EVERYONE I HAVE A WOTHINGTON TRACTOR BUT KNOW NOTHING ABOUT IT CAN SOMEONE HELP ME ALL I GOT IS THE SERIAL # ON THE DASH PLATE IS C 2665 AND IT SAYS WORTHINTON MOVER ON IT IS THERE A SITE OR CAN SOME ONE EMAIL APIC OF THIS TRACTOR SO I CAN START FIXING IT UP IT HAS A DODGE PLATE ON THE GRILL BUT IT IS COVERED UP WITH A BLANK PLATE OVER TOP ? HAS DUAL WHEELS ON BACK SET IS ON THE LEFT THANK YOU ALL ANY HELP WOULD BE NICE THANKS BOB
Orest
10-21-2004 10:29:07
 Re: WHICH WORTHINTON TRACTOR DO I HAVE ??? in reply to BOB WOOD, 10-20-2004 19:27:19
Found this on a web site.
The Worthington Mower Company made front drive, rear steer, golf course tractors based on the Model T Ford from 1919 to 1921. While production numbers are not available it seems likely that fewer than 200 of these model tractors were sold. From 1922 to 1930 they sold a front steer, rear drive, Model T tractor. Serial number records indicate that 1009 tractors were sold. The Model A Ford based tractor was in production from 1929 to 1933 with a production run of 430 units. The Model B Ford based tractor was in production from 1933 to 1939 with a production run of 1089 units. In 1939 Worthington began selling the Model C tractor with a 6 cylinder Dodge motor.
Steve(OR)
10-21-2004 09:28:44
Why don"t you post a pic of your tractor so that any who recognize it can help you out?
Weirsdale George
10-21-2004 08:25:49
Worthington Tractors are an unusual item to have. I have one and have only seen two others at tractor shows over the years.
The problem with this manufacturer is that they build tractors out of whatever parts were available. In the 1920's, it was Model T parts and in the 1930's, it was Model A parts. During the '40s and '50s they built tractors out of what ever was at hand. I have a Model G-6, SN 2582, which I am told was built around the mid-1950's, but cannot verify that. (If it will help you, my tractor has a Continental F162 4-cylinder Red Seal power unit coupled up to a Dodge [from what I am told] 4-speed truck transmission and rear end. It will probably do 50 MPH easily, but with a short wheelbase and without any suspension I have only had mine up to 35-40 MPH -- too scary.)
CGS
05-10-2006 09:26:41
 Re: WHICH WORTHINTON TRACTOR DO I HAVE ??? in reply to Weirsdale George, 10-21-2004 08:25:49
I believe mine is also a G-6 with a continental engine, built around 1958.
C.Reed
01-09-2007 19:55:11
 Re: WHICH WORTHINTON TRACTOR DO I HAVE ??? in reply to CGS, 05-10-2006 09:26:41
I just picked up a "barn fresh" G-6 # 2615 . Anyone have pictures and thoughts to share on restoring it ?
Wade King
03-23-2006 16:49:51
I just got one of there tractors, mine was built in 1955 it is model g- 2 with a serial # of 2045. I am not yet sure what tranny is in mine, but I think it is a contental motor. Anyone with more info, let me know. thanks
bob wood
10-20-2004 21:40:16
can you or any body tell me what yr it is or what kind of motor i need rotor and cap and plugs but not sure what to get does the s# C2665 tell me what yr or what motor is in it thanks bob
jd-tractor
10-20-2004 19:33:28
bob get a hold of a Jacobsen commercial dealer that is a mowing tractor for golf courses ,athletic fields etc.
Orest
10-21-2004 10:13:36
 Re: WHICH WORTHINTON TRACTOR DO I HAVE ??? in reply to jd-tractor, 10-20-2004 19:33:28
This site might help.
There 3 pages of pics.
bob wood
10-21-2004 12:05:17
 Re: WHICH WORTHINTON TRACTOR DO I HAVE ??? in reply to Orest, 10-21-2004 10:13:36
well does this tractor have a ford motor or how should i look up motor specs. 6cyl what or does the ford n the same thanks
