Tractor Talk Discussion Forum
Farmall Regular Serial numbers
Sloroll
10-17-2004 20:30:11
I need to know if the prefix designation of Regular serial numbers changed on both the block and the data plate fron QC to T the same year. My Block has QC stamped before the serial number however it looks to be newer than 1926. It has the flat sided governor on it. SO did the blocks continue to be stamped with QC after the tractor serial number was prefexed with a T? I no longer have my data plate.
Noah W
10-17-2004 22:08:35
 Re: Farmall Regular Serial numbers in reply to Sloroll, 10-17-2004 20:30:11
Hope this helps. No letter prefixes listed so the letters may not matter, only the #'s.
Beginning # Year
501 1924
701 1925
1539 1926
5969 1927
15471 1928
40370 1929 75691 1930 11784 1931
13182 1932
If your regular is like mine, regardless of the SN, there is a mix of casting #'s that don't add up. I think mine is a 1927 Regular, but this thing may have parts from other years, being as old as it is.
sloroll
10-18-2004 04:14:23
 Re: Farmall Regular Serial numbers in reply to Noah W, 10-17-2004 22:08:35
Thanks again Noah. Still like that name. I think you are the first Noah I have met (met?).
