Tractor Talk Discussion Forum
Getting rid of moles
SWMO Chris
10-17-2004 19:05:22
I need some help getting rid of moles from my yard. I am afraid if I step on one of there moles hills i will fall to China. Anybody got any good ideas? Please let me and thanks for your help, Chris
Bob - MI
10-18-2004 05:44:21
 Re: Getting rid of moles in reply to SWMO Chris, 10-17-2004 19:05:22
I use the Nash Choker Loop traps and have good luck. I have 3 of them now and can keep up with the invasions. A pretty simple device available most places with all the mechanism below ground. great for those with kids and dogs. Find the active tunnel, step a section down hard, cut slits in the ground with a spade for the wire loops, and place the trap flush with the ground. When the mole comes back through he pushes the dirt up and the loops snap up and squeeze him to death. All the action is below ground. Really effective and kind of fun.
You should be able to find them for about $12.00 most places. I have loaned my traps to folks many times and soon they have one of their own.
Good luck
INCase
10-18-2004 05:34:06
well.. this may sound odd but we've had good luck with it. Take Tide power laundry soap (has to be Tide) and spread it over the entire yard (it may stunt the grass a bit). I don't know if it deters the moles or kills the grubs and the moles go away but it worked...
Nor. Al.
10-18-2004 05:01:21
Chris My late in-laws bought these beans that make a plant and produce lage pods of seeds , and they were called mole beans ,which I found out the real name for them was Castor beans and that they can be ground up and produce a deadly poison, anyway the moles eat the roots and it totals them out, the plants come back each spring on their own. We have 4 beds of them for about 10 yrs. and theres not 1 mole hill that I can find.You can usually find the seed at flea markets and probably buy them over the internet . just do a search for Castor beans or mole beans.
lucas boy
10-17-2004 22:21:10
i killed 24 this year,25 last year and 16 the year before. i use a scissor trap i got at gemplers.com.they have two of this type trap and the cheeper one works better cause it has a more sensitive trigger.sometimes i have totally exposed the tunnel a few inches and placed the trigger there down in the opening with the scixxors at each tunnel opening and had very good luck.the spike type works but not as well. if you go out and walk all the tunnels down ,then you can check a couple times a day to see where they are currently digging,walking the tunnels down is the key ,so you know where they are active..when you go out to check,take a shovel and walk slow and quiet and look at the ends of the tunnel,you can often find them working,sneek up behind them and push the shovel quickly in all the way right behind them and flip the dirt over along with the mole.if you missed,quickly go about 10 feet back the tunnel and dig up the tunnel to where you first turned the dirt over,ive gotten many this way..the key to success is walking down the tunnels to find where they are currently digging,once you find it you can work that same tunnel and get a few.. you cant really catch one in the big mounds of dirt they push up because they can be a foot or two from that spot pushing the dirt. they can move very fast and close off a tunnell so the carbon monoxide method rarely gets one. the vibrators home depot sells that you push down into the soil will first attract them and then they will leave the immediate area to about a 30 foot radius of the vibrator.so several would be needed if you have a large yard.i like to stand near a active tunnel with a shovel while i think or pray (instead of sitting in the easy chair thinking or praying) and sometimes they will start digging.lucas the mole catcher
Chris(WA)
10-17-2004 20:48:39
We had mole trouble for years! Tried killing them. Best thing was a railroad flare down the holes. Gassed them good. M-80's were fun and worked good too. The problem is that they are territorial and once you kill them the relatives move in on the vacant territory. What we finally did was to get one of those windmill things that the advertise in seed catalogs. One of the guys below called it a Whir-a-gig. I am not big on gagets like that but danged if this thing doesn't work slick! Have not had a mole in better than 5 years! Get one, it works!
Richard Scott
10-17-2004 20:22:28
Lots of info on stuff that doesn't work is out there. If you use a gas engine, make sure it isn't a modern car; with the pollution controls it doesn't put out enough CO to do the job.
Here's what works:
Confirm the area is in use at this time by running your garden hose down thru the center of the mound into the holes and washing as much dirt as you can back into the tunnels. If this area is in use, he will push the dirt back out again in a day or so. They often have such large networks they might not come back to a particular part for weeks. You need an active area.
Locate the runways by probbing with a rod or a very long screwdriver. Runways are not under the mounds; they go off to the side to push the dirt out, so the runway won't be under the mound.
Get an "Out o' Sight" trap. Hop it up by grinding down the trigger mechanism (grind down the lip on the plate--you'll figure it out when you see the trap). You want the rod to slip off easily. Leave only about 1/32" of lip.
Dig into the tunnel, making a hole about 6" x 6" if you can keep it that small. Put a mound in the middle of the tunnel to make a hump--a rock works well for the hump. Being sure to keep the safety mechanism in place, set the trap in place to straddle the hump--make sure if you use a rock that the rock won't keep the trap from slicing the critter in half. Set the trap deeply enough that the critter has to go up against the trigger plate to go over your rock or mound. Undo the safety, then place a bucket over it to keep the light out.
Check it frequently. Coyotes will make off with the trap if it has a mole in it--don't ask me how I know!
Give it a few days in that one spot, then move on if unsuccessful.
Good luck!
Richard Scott
DRL
10-17-2004 19:55:21
Used to put lime in the garden to keep them away. Don"t know why it works, but they seemed to stay out when we treated, came back if we didn"t. Worth a try.
Bob
10-17-2004 19:46:49
Have you tried the rodenator? Watch the videos at this site:
stan
10-17-2004 23:13:22
 Re: Getting rid of moles in reply to Bob, 10-17-2004 19:46:49
This looks like it will work, what happens if you are standing over one of the tunnels,when it goes off? Ouch
Davis In SC
10-17-2004 20:26:31
Rodenator looks like a fun way to get rid of moles !!! I wonder if the PETA folks have seen it yet ???
Leland
10-17-2004 19:43:10
Use any gas engine put hose on pipe and put hose in hole pack dirt around hose to seal let engine idle for a couple of hours works good until the ones next door move over then repeat .and stepping on mole hills will not cause you to fall to china. it is safe to do so.
Roy in UK
10-17-2004 23:14:55
 Re: Getting rid of moles in reply to Leland, 10-17-2004 19:43:10
Many years ago a vet I know rid his lawn of moles ( yes we get the little buggers too!) using his car exhaust connected to a length of hose, with the other end shoved down a mole hole.Apparently it worked. As I said it was many years ago so by definition it was not a "modern" low emission engine.
TimFL
10-17-2004 19:42:39
You can buy traps for them. They are tricky to set up but seem to work fairly well. Pesky little critters they are.
Tim
msb
10-17-2004 19:17:00
Whirl-i-gigs are supposed to create vibrations the moles are not comfortable with.
A friend who is a turf agronomist(teaches at Purdue) says a mole's favorite food is earthworms(yea, I know it is supposed to be grubs but he insists).Anyway he says anything that will kill earthworms will eliminate their food source and they will leave.Where is the aldrin when you need it?
Kerry Miller
10-17-2004 19:51:11
 Re: Getting rid of moles in reply to msb, 10-17-2004 19:17:00
I have a lot of problems with them here in SE Texas (Victoria, between Houston and Corpus). There was an article about them in the paper today, so I must not be the only one. The article said they eat grubs, so if you put out poison for the grubs and get rid of them, the moles will go away. I'm going to try it, because not only do I have the moles, but also 2 dogs who try to dig them up. By the time they're finished, my back yard looks like it has been bombed.
