Tractor Talk Discussion Forum
Old Tractor Subject.... :)
Allan in NE
10-15-2004 16:54:18
Okay, I need somebody smart.
Got this old tractor, it really doesn't matter the make.
I want to put power steering on the old sow using one of those Char-Lynn actuator/orbital motor gizmos.
Just acquired a live pump (no valving just a straight gear pump), which is driven by the timing gears, but all I wanna do is to run that power steering motor gizmo; heck with anything else.
I want to plumb into that Char-Lynn, thru and out to the can.
Do I need to have some kind of a pressure release or a pressure proiority valve thing? Those that use auto pumps don't 'cause they are built in on those types.
Okay, I know you all know the answer to this and if you don't answer me back, I'll assume you're still torqued off at me about my not wanting to go vote or some such thing. :>)
Thanks,
Allan
third party image
JRM
10-16-2004 05:44:14
 Re: Old Tractor Subject.... :) in reply to Allan in NE, 10-15-2004 16:54:18
Been following your post and get a kick out of them. Professing to know nothing about the pump in question, I can help you keep this political so's not to confuse anyone. I guess it will depend on whether the pump spins to the left or the right..... :-)
Allan in NE
10-16-2004 05:52:05
 Re: Old Tractor Subject.... :) in reply to JRM, 10-16-2004 05:44:14
JRM,
LOL!!!!!
Atta boy, good attitude for it bein' so darned early in the morning!
My wife keeps tellin' me that I spend too much time talkin' to my tractor buddies. Goofy woman anyway! :>)
Allan
Nebraska Cowman
10-15-2004 20:39:36
Allan, You are on the right track. Just ask Mitch, (Farmallkkid) about running one with the outlets plugged!!!
Harley
10-15-2004 18:49:28
Man that's a good looking pump Allan, and familiar too, Harley
Paul in mich
10-15-2004 18:00:26
Allan, Is that tractor of yourn a Damercrat, or a Rebublikun? Dang it all, you know this is a political forum, not just somewhere you can arbitrarily discuss tractors. Have you lost yer mind?
Joe (Wa)
10-15-2004 18:39:03
 Re: Old Tractor Subject.... :) in reply to Paul in mich, 10-15-2004 18:00:26
Sorry you may have to post your tractor question on another forum. Tractor Talk is presently dedicated to politicians and their lackey chestbeaters.
But then you are a pretty good sort so perhaps squeezing in one tractor question won't precipitate serious criticism.
Char-lynn torque generators used on older tractors are rated from 3 to 6 gpm at max 1000 psi.
There is no relief valve in the torque generator, hyd circuit is off-center/followup and the rotating element. You will need a relief in the piping or the pump.
There is torque generator info at the bottom of the page at the link. A common torque generator found on older tractors is the 217 series 3.5 gpm unit.
Joe
Allan in NE
10-15-2004 18:06:05
Ouch!!! :>)
Get that dern sharp stick outta ma eye! :>)
Paul in Mich
10-15-2004 19:15:57
 Re: Old Tractor Subject.... :) in reply to Allan in NE, 10-15-2004 18:06:05
Surely thou knowest I jest. Sorry for calling you Shirley.
Coloken
10-15-2004 17:32:43
Hey, I'll still talk to you. I recognize that pump. Have had one for years but never could find a manafold to hook it up to various things. To your question, I think it would be wise to have some kind of pressure bypass. That pump might have a pretty high volume..more that the other unit can handle. I have in my junk box some little valves that were designed to bypass "shock" loads when running hyd motors. Some think like that? Or even tie in an old gresen valve some where in the circuit?
joe e-tx
10-15-2004 19:43:21
 Re: Old Tractor Subject.... :) in reply to Coloken, 10-15-2004 17:32:43
allen you seem to have much to much time on your hands, can i bring my jd 450 dozer,mf 40 back hoe,47 h farmall for you to fix with your magic????
joe
