Tractor Talk Discussion Forum
over-run coupler
jmh
10-11-2004 16:44:09
Found a p.t.o. over-run coupler on a unused B Farmall. Can someone tell me how to get it off? Is it pinned on or what? Thanks..... ....
Steve(OR)
10-11-2004 16:48:54
 Re: over-run coupler in reply to jmh, 10-11-2004 16:44:09
Assuming it is the same as used on our Fords - Remove the 2 zerks (grease fittings). Then the holes can be aligned with a 5/16 rollpin that can be driven out with a punch.
Allan in NE
10-11-2004 16:52:33
 Re: over-run coupler in reply to Steve(OR), 10-11-2004 16:48:54
Steve,
Are those things dog-driven or just a sprag gizmo, or are there both kinds?
Never been around one, other than on a store shelf.
Thanks,
Allan
Steve(OR)
10-12-2004 04:09:53
 Re: over-run coupler in reply to Allan in NE, 10-11-2004 16:52:33
Don"t know what a sprag gizmo is. There are a couple of pawls (I believe spring loaded) inside that engage a toothed surface to drive the ORC in only one direction. A lot like a rear sprocket on a bicycle.
