Tractor Talk Discussion Forum
JD 3010 steering problems
Henk.
10-11-2004 09:45:08
My JD 3010 steers very hard and very slow to the right.To the left there is no problem and also the other hydraulics work well.This problem happend a few days ago while moving topsoil with the frontend loader.Does anyone know how to fix this?
jdemaris
10-11-2004 20:04:27
 Re: JD 3010 steering problems in reply to Henk., 10-11-2004 09:45:08
Could be one of many things, but I'd suspect the steering valve first. It has a set up adjustable rocker arms inside of it, two that control left hand turns and two that control right hand turns. Could be that one side is coming apart or has come loose.
Bob
10-11-2004 09:56:53
Check for a bent spindle, or anything else binding in the steering mechanism, and be sure the steering lines that travel up to the front have not been crushed.
Otherwise, you have a bad steering MOTOR up front, or a bad steering valve.
Begin by tee'ing into the steering pressure lines up front, near the radiator, and check your pressures, while rotating the steering wheel in both directions. A lack of pressure when steered right, or high pressure on BOTH lines when steered right would probably indicate a bad steering valve.
