Tractor Talk Discussion Forum
tractor and bush hog
mark peipert
10-09-2004 21:50:22
I need a tractor and for use with a 5 foot bush hog. would some one please tell what tractor to use or not use? I have a chance to buy a ford 8n or ford 800 would either work or is there something better?
thanks, mark
Leland
10-10-2004 19:40:28
 Re: tractor and bush hog in reply to mark peipert, 10-09-2004 21:50:22
Mark what ever you buy just make sure it's got a live pto.
Dug
10-10-2004 07:35:22
Hi Mark,
Either tractor would pull a 5 foot hog fine. However, the 800 is a much stronger tractor (I believe it is close to 50 hp and the 8n is around 35.) The only problem with your choices is the lack of live PTO. Live PTO keeps the shaft spinning with the clutch in.
And follow Sid's advice on the override clutch if you do not have live PTO.
Dug
Bus Driver
10-10-2004 15:23:43
 Re: tractor and bush hog in reply to Dug, 10-10-2004 07:35:22
University of Nebraska tested the Ford 8N. The test of 1050 showed 25.49 belt horsepower. Drawbar HP is typically a bit less than belt. Apparently they did not test a model 800. An 841 tested in 1958 produced 43.1 belt HP.
paul
10-10-2004 18:44:55
 Re: tractor and bush hog in reply to Bus Driver, 10-10-2004 15:23:43
All the 800 tractors will test about the same - 820 - 871 models. An 860 or 861 will have a live pto. Lesser middle numbers will not, an graeter middle digit will have live pto with the sometimes problematic SoS tranny.
Any of the 800 series tractors is a better machine than an N - more power, live hydraulics, the possibility of 5 speed, llive pto, power steering.....
--->Paul
stan
10-09-2004 22:45:46
I used a Ferguson TO 20 with a 5 ft mower. This tractor may be just a little stronger than the 8N. In heavy stuff I ran out of power. I got a MF 203 with a 3 cyl Perkins diesel. With it I can run a 6 ft mower. The perkins will bog down a little in real thick green stuff, but will do almost everything I need it to do.
Sid
10-09-2004 22:24:47
Of the two the 800 would probably be better. If you get a tractor without some type of live PTO be sure to get an overunning clutch for the PTO. It is my opinion that live PTO is much better for a number of reasons.
Mark Peipert
10-11-2004 07:40:26
 Re: tractor and bush hog in reply to Sid, 10-09-2004 22:24:47
Thanks to all that replied. I think i'll wait vand find a live PTO.
Mark
