Tractor Talk Discussion Forum
Manifold crack
GeorgeH
10-09-2004 15:02:15
I just discovered (gotta quit cleaning recent acquisition) a hairline crack in my H manifold right behind the center vertical (one of the intake pipes) maybe 1/4 to 1/3 way around.
What are my repair options??
GeorgeH
10-12-2004 23:57:55
 Re: Manifold crack in reply to GeorgeH, 10-09-2004 15:02:15
Found some stuff at Advance autoparts good for 2000 degrees. If doesn't hold, guess will replace. Many new ones available and also found used one at local grave yard.
Dave Tx
10-09-2004 20:30:30
I repaired mine with JD Weld. Haven't seen much that it won't fix.
george md
10-09-2004 18:29:36
George,
If you want a permanent repair then oxy/acet
with cast iron rods is the best repair. if you want a repair that might be alright now but has a good chance of cracking due to
the expansion and contraction caused by the
heating and cooling of the exhaust, then arc
weld it .
george
geok
10-09-2004 16:39:55
Might consider replacing with new.
