Tractor Talk Discussion Forum
1951 8n Tractor Oil TYpe
Kevin freber
10-09-2004 09:50:18
I"m trying to find out what type oil is recommende for 8N tractors any help?
Leland
10-09-2004 23:52:26
 Re: 1951 8n Tractor Oil TYpe in reply to Kevin freber, 10-09-2004 09:50:18
Just go to wally word and get 15-40 shell rotella oil best stuff you can dump in that old motor best anti wear packages in the world.
Dave Tx
10-09-2004 20:40:36
I've got a 1950 8N and I always run 20-50 here in Texas. The motor has been overhauled so running detergent oil is no problem. Some people will argue that old motors that have a lot of carbon build-up that its bad to use detergent oil since it can break loose the carbon and cause a problem in your motor. If it is an older motor that has not been overhauled I would run the 20-50 and change my oil after a few hours.
lucas boy
10-09-2004 11:57:38
i use 30w detergent oil in mine unless itss really cold,then i use 10w30 ..lucas
Pitch
10-09-2004 16:01:29
 Re: 1951 8n Tractor Oil TYpe in reply to lucas boy, 10-09-2004 11:57:38
That is a fight that has beeen going on on the N board since its inception. The manual wants non detergent 30 weight for summer and lighter non detergent for winter. Some folks insist that the manual calls for that so thats what must be used. The manual wants that because multiwt detergent oil hadn't been invented yet when your machine was designed. I use a brand name detergent of whatever happens to be on sale been running it on that for the almost ten years that I,ve owned it. My engine is a bit tired and the pressure is a bit low so I like 20/50. No matter what you run make sure to do regular changes cause it is not a pressure filter and the oil gets dirty quite fast.
