Tractor Talk Discussion Forum
Rusty fuel tank
Jubilating
10-05-2004 20:26:29
I have a question similar to one just posted about a rusty fuel container. I have a rusty tank on my Fford NAA. I am planning to remove the tank and have it sandblasted, then coated with something. (suggestions?) Is sandblasting the best solution or is there a better (cheaper) route. The rust is a fine particulate the best I can tell.
Thanks,
Tom
Ralph/R.E.B.
10-06-2004 17:51:04
 Re: Rusty fuel tank in reply to Jubilating, 10-05-2004 20:26:29
i had same problem with my allis chalmers c fuel tank looked pretty bad tryed several things,then come across PERMATEX DISOLVER GEL got a tractor supply store ,dumped 12oz bottle in tank and rolled tank around so as to coat inside good then set it at every angle i could, let it set at each angle for about 10 minutes flusher with water till clear then half of box backing soda and water then treated with oil till i get it back on tractor i was amazed at what a good job it did ,for about $5.00 bucks it is worth a try. good luck Ralph
Jubilating
10-07-2004 07:26:15
 Re: Rusty fuel tank in reply to Ralph/R.E.B., 10-06-2004 17:51:04
Thanks for the suggestions. I ordered some Kreem from the local cycle shop and will give it a try. I appreciate your time.
Tom
Kendall
10-06-2004 06:21:04
I used Kreem on both my Harley and Super A and was pleased with the outcome.
Mark - IN.
10-06-2004 17:45:06
 Re: Rusty fuel tank in reply to Kendall, 10-06-2004 06:21:04
Is good stuff. Did my hog too, no problem so far with chipping or any of that. The Deere has a plastic tank, so no bother. But this winter will hit the Allis B and the wheel horses. My experience has been great for steel tanks. My scooter shop ordered through Drag Specialties or V-Twin. Use the tank prep, then coat.
