Tractor Talk Discussion Forum
HELP WITH MY FORDSON TRACTOR
wanda
10-03-2004 16:38:41
Just purchased a 1937 Fordson Tractor.
All internet information says this is a model N #820125, but on the actual tractor it says made in England...maybe this part is not the orginal ???
My main question is can this tractor be pull started? One foot petal/lever, half petal clutch full petal brake.
Any information from some one knowing about these tractors will be of great help....!!!
Thanks....
wanda
10-03-2004 17:55:59
 Re: HELP WITH MY FORDSON TRACTOR in reply to wanda , 10-03-2004 16:38:41
Thank you Bernie ...
so many questions i have with my new toy...!!!
maybe you might help on this .... I tryed pulling tractor and wheels would not turn/locked down till i put it in neutral maybe a sign of a bad clutch or a stuck clutch??
Bernie in MA
10-03-2004 18:29:53
 Re: HELP WITH MY FORDSON TRACTOR in reply to wanda, 10-03-2004 17:55:59
If you had it in third gear the engine should have spun. I haven't run mine for years and I can't remember where third is. Can you handcrank the engine? If not, it's likely stuck.
Bernie in MA
10-03-2004 17:15:18
They were made in England starting around '28, I think. I have a '25 that I've pull started many times. A bit of caution, when it starts it might gain on the pulling vehicle and you might be unable to stop if the clutch sticks. You can put it into neutral to stop, but the puller has to be ready to stop instantly. My daughter was pulling me and when she saw me gaining on her she speeded up, just as I put the tractor in neutral. The chain snapped. I was lucky, the short end was toward me and whacked the tractor hood/gastank. The long end went over the pickup bed and put a good crease in the cab roof. Be careful.
