Tractor Talk Discussion Forum
Top Link Adjustment Bar
Joe MD
09-28-2004 09:48:31
I had to buy a new top link at TSC.
Yet again, I was puzzled at what you are supposed to do with the bar that comes taped to the side and is meant to turn the top link to adjust the length.
Are you supposed to just hammer these things in with brute force? They don't readily fit through the hole.
Allan in NE
09-28-2004 09:53:59
 Re: Top Link Adjustment Bar in reply to Joe MD, 09-28-2004 09:48:31
Hi Joe,
Yep, just hammer it thru the body hole. By it's design with those little "ears", it then will not fall back out.
Allan
Bob Semrau
09-28-2004 09:52:41
That's what I did on mine. Unfortunately, after 7 years it now sometimes slips through one of the holes. Non a very good design ...
Dieselrider
09-28-2004 15:49:11
 Re: Top Link Adjustment Bar in reply to Bob Semrau, 09-28-2004 09:52:41
With the pin through both holes, tak a punch and strike around the hole it wants to slip out of to re-crimp it. It's worth a try.
ShepFL
09-28-2004 13:21:09
I have one I copied from a an old timer. He welded round stock in a ring around the pin. It acts like a steering wheel of sorts. Been wanting to do the others but have not made time for it.
Added benefit is when needed you can really "heave-ho" on that thing when it gets stuck or you're doing some final adjustments in the field. Also, assuming your rig is shutdown while in the field you can adjust reach back and adjust from tractor seat.
FWIW
Allan in NE
09-28-2004 09:55:59
Bob,
Are you by chance any relation to Al Semrau in Williston, ND?
Allan
Bob Semrau
10-03-2004 18:53:13
 Re: Top Link Adjustment Bar in reply to Allan in NE, 09-28-2004 09:55:59
Allan :
Sorry I took so long to check back here, but no, all of my (known) relatives are in Michigan.
