Tractor Talk Discussion Forum
Oliver Super 55 Power Steering
58Super 55
09-25-2004 17:19:34
What is causing my power steering pump to lock-up? I have tore it down sveral times and it still will lock. The last time it sheared the gear shaft. The Oliver is a 1958 Super 55. It has the same setup as a Chevrolet. The pump mounts to the back of the generator via an extended shaft with gears cut to drive the pump.
Paul Janke
09-26-2004 06:40:46
 Re: Oliver Super 55 Power Steering in reply to 58Super 55, 09-25-2004 17:19:34
Is it possible the pressure relief valve is not working? Coming up against an overload without a pressure relief can cause extremely high pressures and forces.
