Tractor Talk Discussion Forum
electric cab heater
Jim in NH
09-23-2004 04:37:39
Hi Folks,
I'm looking at an AGCO 5660 tractor, which I understand uses an air-cooled engine, and will need to add a cab with heat. The cab data I've found however indicates that I can't add the heater with an air-cooled engine.
Is it reasonable to think I could put in an electric cab heater? Are there such things? Maybe need to upgrade the alternator at the same time?
Thanks,
Jim
CJ
09-23-2004 12:38:45
 Re: electric cab heater in reply to Jim in NH, 09-23-2004 04:37:39
Trucks & equipment w/ air cooled engines used engine oil for heat,as Jon said.
Jon H
09-23-2004 11:09:03
The 12V heaters do not put out enough heat to keep you warm. seems I remember a combine with aircooled engine(Gleaner ?) that used a heat exchanger that used the hot engine oil to heat the cab.
JHesler
09-23-2004 10:48:46
How about a propane furnace from a small RV trailer. They sell even smaller ones boats.
darrel (nd)
09-23-2004 09:05:30
I run cranes for years and thay had porpane or fule heaters in them and all it takes is 12 volts to mahe them run
Allan in NE
09-23-2004 08:21:01
How's about one of those 12 volt in cab car heaters?
They still sell those things?
Allan
Rod F.
09-23-2004 07:59:06
I once worked on a small wheel loader with a Hatz air cooled engine. The cab was heated with a propane heater. IT is generally not easy to tap into the air box of those engines, if you could. Personally, i would not want to heat a cab like that. Think of the stray combustion gases (stink tube etc.) blowing in your face. Propane is not that expensive.
Rod
ChrisL
09-23-2004 06:00:15
Just because the engine is air cooled does not mean it doesn't get warm. run a little duct work to pass air over the exhaust manifold to gain heat and heat the cab with that air.....
or make a small water circulating system and run the water around the exhaust manifold for some super heat....
Mark - IN.
09-23-2004 20:52:25
 Re: electric cab heater in reply to ChrisL, 09-23-2004 06:00:15
Chris, you're exactly right. Seen many a tractor in the winter time where the engines wear shrouds, ducted back to the cab, and the radiator fan forces the heated air back. TSC advertises such a shroud in their catalog - the only thing missing is a cab with windows to open to vent fumes and to cool one off as they're pushing snow around in their T-shirt because sometimes gets a little too warm in the cab. Need a cheap cab? Angle iron, flat bar, and plexiglass work just fine behind such a shroud.
Got a fan on that air cooled engine to move heat off of it? Mount one, it'll help in the summer months too.
TheRealRon
09-23-2004 05:15:28
There are high-output aftermarket alternators that are used typically for welders and produce 120v. Many off-road fanatics use them. You could just plug in a milk house type heater.
See
