Tractor Talk Discussion Forum
10-20 McCormick Deering
Curt Kluver
09-22-2004 19:31:39
I have a 10-20 McCormick Deering that I am getting running. So far, we got it to run, we just can't get it to take gas. We can give it a little through the breather and it will run for a few seconds, and then it will quit. We checked all the gas lines, all OK. All the plugs in the carb have gas coming to them. What should I do now?
Brian in Ohio
09-23-2004 10:03:59
 Re: 10-20 McCormick Deering in reply to Curt Kluver, 09-22-2004 19:31:39
If you disconnect the fuel line from the carb, are you getting good flow from the tank?
curt Kluver
09-23-2004 15:12:01
 Re: 10-20 McCormick Deering in reply to Brian in Ohio, 09-23-2004 10:03:59
Yes, it is very constant and steady.
Nebraska Cowman
09-23-2004 05:22:03
have you had the carb apart? something is plugged.
Curt Kluver
09-23-2004 15:14:06
 Re: 10-20 McCormick Deering in reply to Nebraska Cowman, 09-23-2004 05:22:03
Hey, Ill try that, Thanks
