Tractor Talk Discussion Forum
gm goodwrench diesel pump
jjmcdon
09-20-2004 10:45:09
ive got a goodwrench diesel with a roosa master injection pump. fuel is getting to the center of the injection pump but not to the injectors at all. i have spent hours just cranking it and no fuel is getting to the injectors and i have the throttle half way and sometimes full throttle. Just a tiny, tiny bit of air bubbles is being bled through. Is something stuck like a metering valve? All info appreciated tia.
jjmcdon
09-21-2004 05:30:10
 Re: gm goodwrench diesel pump in reply to jjmcdon, 09-20-2004 10:45:09
sorry ment 86-89
RJ-AZ
09-20-2004 20:04:03
Check for a restriction in the return line or for debris in the return fitting coming out of the top of the pump. Also be sure the pump is energized and has a complete circuit. ie. check the little ground strap.
Everett
09-20-2004 18:22:03
Had that happen on my 6.2 Chevy. Had to remove the top of the fuel pump. The rod that the solnoid operates stuck. Just worked it by hand a few times and it loosened up and started working right again.
If I missed something, someone will help out
Everett
Allan in NE
09-20-2004 11:35:21
Hi,
What year? Are you energizing the fuel solenoid?
Allan
jjmcdon
09-21-2004 05:24:46
 Re: gm goodwrench diesel pump in reply to Allan in NE, 09-20-2004 11:35:21
like a 78-79 it does have that fuel solinoid and i took the cover off and saw that fuel solinoid but it is not working opening or closing at all when i put electricity to it so im gona buy a new one what does this fuel solinoid exactly do?
jjmcdon
09-21-2004 10:12:51
 Re: gm goodwrench diesel pump in reply to jjmcdon, 09-21-2004 05:24:46
yep the solinoid was bad i put a zip tie to hold it back and it started now when i want to shut her down i will just cut the fuel of somehow or someway everyone thanks for ur ur help.
Allan in NE
09-21-2004 05:39:46
Hi,
That's your problem. They would go out once in awhile.
GM needed an electrical "shut off" because of the way their "variable throttle" worked. When you kill the switch, it in turn kills the fuel at the pump and shuts down the engine.
Be very, very careful when you replace that coil. If you don't get the linkage hooked up just right, when you start the thing, the engine will run away from you and you cannot shut it off.
I would have a pair of needle nosed vice-grips handy so if you have to, you can pinch off that rubber line; this will kill the engine in an emergency.
Allan
