Tractor Talk Discussion Forum
Cylinder head re-torque
Al V.
09-19-2004 19:32:30
What are the general rules for a cylinder head re-torque? should the engine be hot? Should I crack each bolt loose and then retorque it? One at a time of course.
Weirsdale George
09-20-2004 13:41:07
 Re: Cylinder head re-torque in reply to Al V., 09-19-2004 19:32:30
Unless specifically called out in the manual not to, I always retorque. (Years ago I didn't retorque a Rambler American engine and ended up blowing a head gasket -- cost me a lot of time, some money and a little embarrassment.)
moed
09-20-2004 07:45:56
What should the torque value be on a John Deere "A" head bolt?
1945 A
09-20-2004 11:19:48
 Re: Cylinder head re-torque in reply to moed, 09-20-2004 07:45:56
I don"t retorque the head bolts either, although I"ve read lots of folks that do. When installing the head (initial) I DO go back and double-check all the bolts for correct torque.
The torque on the John Deere A head bolts---- 125 ft. lbs, and be sure to use the lead washers beneath the bolts!
moen
09-20-2004 19:38:51
 Re: Cylinder head re-torque in reply to 1945 A, 09-20-2004 11:19:48
What should the torque value be on the nuts that bolt the block up to the crankcase?
txblu
09-20-2004 05:35:11
I don't retorque period. Never had to .
Mark
johndeeregene
09-19-2004 20:16:34
you should always retorque the head when hot. i usually do it after about 10 hrs of use. i know people that retorque after 1 hr use also. do it in the same sequince that you tightened them in also.
johndeeregene
RAB
09-19-2004 23:02:33
 Re: Cylinder head re-torque in reply to johndeeregene, 09-19-2004 20:16:34
I know we are talking tractors here and (almost) all have cast iron heads, but for those who also work on other engines - never retorque an aluminium head while hot, let it cool completely! Unless the manual says diferent, of course.
Regards, RAB
