Tractor Talk Discussion Forum
300 utility 12 volt conversion
albert boulais
09-14-2004 15:01:42
I am finished playing with 6 volt system any info on a kit or possably an altenator with the right shaft size that i can put the origional ajustable pully on so i dont have to modife the skin ?
300 Randy
09-15-2004 07:13:27
 Re: 300 utility 12 volt conversion in reply to albert boulais, 09-14-2004 15:01:42
Buy a small GM alternator at a bone yard. It bolted right up to the generator bracket on my 300. The only thing I had to do was remove the sheetmetal brace under the hood piece as it was hitting it. Good luck
TheRealRon
09-15-2004 05:23:53
Delco alternators use many different size pulleys. You can even buy aftermarket pulleys. On a tractor, it's fine to use a smaller pulley. Check an auto parts store or junkyard. Delco 10Si alternators are a dime a dozen. Don't know if your pulley will fit but it's easy to find out.
There's an article on this site on how to convert to 12v if you need it.
