Tractor Talk Discussion Forum
OT. Ford Pickup
Jerry Cent. Mi.
09-13-2004 16:41:25
I am looking at a 99 3/4 ton Ford 350 with a 5.4 V-8 diesal 3.73 gear ratio. 4 speed auto with liminted slip rearend. Under 10,000 miles with a small dent in the rear cab door. Are these dependable and what kind of fuel milage should I be able to get. I want to pull a trailer with two 6000 lb. tractors. What do you fellows think. Priced at $20,000.00 Thank you
T_Bone
09-14-2004 07:57:03
 Re: OT. Ford Pickup in reply to Jerry Cent. Mi., 09-13-2004 16:41:25
Hi Jerry,
I would almost call BS on the 10k miles as you can replace a dash with a new odometer reading of anything you want if you don't have alot of scrupples.
My 02 F350 DRW has 16k miles and I don't work and really don't use it all that much so about 5k miles average per year under light use.
Have you ran the vin thru to see the title and warranty history?
GCWR means nothing now as your out of all warranty thru Ford. Your pushing about maximum load with 12k + 4k trailer + 7500 truck but the commerical guys do 30k GCW all the time. I do 28k on mine but not OTR. Have no idea what there maintance expense is as GCW would effect that.
With 16k GCW running from AZ to the Colorado Rockies, RT. I average 14.1mpg pulling by at 1600rpm, maximum torque.
Empty (as empty as I get), I get 19.2mpg consistanly on every tank. I did have to retrain my driving style tho.
T_Bone
Dozerboss
09-14-2004 10:12:20
 Re: OT. Ford Pickup in reply to T_Bone, 09-14-2004 07:57:03
Hey T-bone,
Does, the 02 have the 7.3 powerstroke? Wondering if you have the 6.0? What axle? Hey now, AZ to Co sounds like over the road! But i have done that too to go get something i wanted.
The trailer i use has tandem wheels so i can pull fine with a single rear wheel truck. That was a compromise, as a 4X4 was important, and dually 4X4's are hard to come by. You definately have an advantage if you blow a tire with the dually. With 4:10 gears, i get 17.5 to 18 mpg empty.
I live near an interstate and talk to alot of the light duty commercial haulers when fueling up. They will come off the road with 10 boat trailers stacked on top of one another and three car haulers all the time. The 30,000 lbs is what they say about weight too, with the goose neck trailers. The right trailer is just as important as the truck. I actually saw a 450 dozer for sale on e-bay, and was pictured on a single wheel dual axle trailer pulled with a 1 ton truck with receiver hitch. The dozer weight alone is 14-15K. I asked about how it towed, but only answer i got was trailer is not included. Regards.
T_Bone
09-14-2004 20:57:54
 Re: OT. Ford Pickup in reply to Dozerboss, 09-14-2004 10:12:20
Hi DB,
The 6.0 came out in Nov 2002 for the 03 moodel. Some are reporting 7.3's as late as Dec 2002 build dates and no reports after Jan 03.
I was commenting that I don't do 28k GCW OTR, just a local water trailer.
My son just bought a 04.5 CTD with 6spd, 4:10 and is getting about the same, 18 to 20mpg.
T_Bone
Jim.UT
09-14-2004 08:43:51
T-Bone, it sounds like you've got the truck I'm looking for. Are you ready to sell and buy a new one? If so, contact me before trading in your '02 dually. My email addy is not hid. Thanks!
T_Bone
09-14-2004 09:03:57
 Re: OT. Ford Pickup in reply to Jim.UT, 09-14-2004 08:43:51
Hi Jim,
Na I kept my Dodge for 27yrs so don't hold your breath....lol
The Dodge is for sale tho! $2k 76,cub cab, 400ci, 4spd, 4:10, lwb, 70gal fuel, 250k miles, 1 owner.
Ya I'm real happy with my F350. I had it in deep in the back country last year elk hunting and I sure got some funny looks.
02 F350, CC, 7.3PSD, 6spd, 4wd, lwb, 3:73
T_Bone
JT
09-14-2004 06:06:23
I have a 2000 F250 4 door with a 7.3 PS. Love the truck, get 16-20 mpg empty, never checked it pulling a trailer. Has the power to pull about anything I hook onto it. Now the downside.
I pull a trailer quite often, all tag trailers, with an M Farmall, pulled it great, no problem, put a trailer on it that had a gross weight of a little over 8000 pounds, this is where it gets a little squirrely, it pulls fine going down the road, does not have a lot of problems stopping, but going around a curve, the trailer has a tendancy of pushing the truck a little, this is where I think a dually would be much better. Don't get me wrong, it is not bad enough to feel unsafe, but with the weight you are looking to pull, it will get worse, the more weight you put on the truck, the more it could try to push you when going around a curve.
Dozerboss
09-14-2004 15:45:56
 Re: OT. Ford Pickup in reply to JT, 09-14-2004 06:06:23
Sounds like you have a receiver hitch. Transfering weight of the tractor to the truck will help. In other words more hitch ball weight,less weight on the trailers axles. If the tractor can be moved forward that would help. If not a weight distributing hitch is an answer, a sway control another if the problem is worth the cost of them. Having a load closer to the back of the trailer will really increase push and sway.
Jerry has bought his truck. If its in good shape, he may never want another gas powered truck.
JT
09-14-2004 17:05:03
 Re: OT. Ford Pickup in reply to Dozerboss, 09-14-2004 15:45:56
Yes, it is a receiver hitch, we have probably 75% or more of the weight in front of the axles on the trailer.
Dozerboss
09-14-2004 21:55:12
 Re: OT. Ford Pickup in reply to JT, 09-14-2004 17:05:03
I think i read it right--8000lbs with the trailer and tractor weight. Your truck should be able to handle 8000# comfortably. Road design can make be a factor in how well it pulls. One differance in curves is whether the curve is banked or the not. A flat curve would make the trailer not track as straight and build up some momentum to push the rear of the truck towards the outside of the curve. A race track is a good example. On a banked curve track they can corner at a higher speed, try the same speed on a flat corner and the rear wheels will lost traction and start to come around and spin out the car.
Your right a dual wheel is a little harder to push around. There's no substitue for getting to know how your truck reacts in certain road conditions and adjusting your speed to them. It maybe that a dually would perform better for your setup and road conditions. First, You could try moving the tractor rearward and try to get 60% on the trailer and 40% on the truck and see if its better. Just fine tuning the load for the best ride. There is a point where you can have too much weight on the hitch effecting the ride, just as there can be too much weight on the trailer tail. The sway and fishtail happen when theres too much weight rearward and it's easy to tell when you have reached that point. The alternative to dual wheels is to improve your equipment to reduce the push with the weight distributing hitches with sway bars and also the friction sway controls that mount on a small ball on your receiver block and trailer frame. Either way there are advantages and disadvantages and both approaches have higher costs. Tire, brake and repair costs are higher on duallys. My neighbor complains about poor tread life on his. Plus the wheels are too big for the average tire balancer to have the right adapter. So he ends up looking for places that have the right wheel balancer to buy his tires.
Trailer design comment, i have seen people make trailers with mobile home axles and no springs. They really ride rough and will really push on a truck even when empty.
dhermesc
09-14-2004 05:58:17
Well you have the engine question straight, now just what model is it? An F350 is a one ton, an F250 is a 3/4 ton. Or is it a an F350 with single rear wheels?
bcPA
09-13-2004 23:52:15
All the replies refered to gvwr but I did not notice anyone refer to gross COMBINED weight rating or gcwr. Here in pa that is a important distinction. A 17 thousand pound gross weight rated truck can pull a 10 thousand pound trailer and you get to allow the truck to gross 17,000 and the trailer can gross 10,000. but add a trailer over 10,000 and you must get a new title with a combined weight rating of the combined weights of the truck and trailer ratings. in effect you get to pay for 27,001 pounds or more of license plates and now you are over the magic 26,000 pound number and need a cdl.
Dozerboss
09-14-2004 13:52:38
 Re: OT. Ford Pickup in reply to bcPA, 09-13-2004 23:52:15
That is tough on the little guy moving his own stuff. I wonder if those regulations are because of accidents on the mountain roads, PA turnpike? Probably so, more traffic in that neck of the woods. In contrast, last time i went to N.M. speed limit was 75 mph but they want all trailers to stop at weight station including RV's and tow dollies. They must have stiff regulations too or be looking for illegal stuff.
TheRealRon
09-14-2004 02:26:18
My fault. I intended to post GCWR and got everyone off track.
He needs to know the GCWR of the truck and weigh all the units.
Tim B
09-13-2004 19:38:32
Apparently you are talking about pulling a trailer weighing about 15k to 16K pounds? I think that will be too much for an F-350. I have the 2001 version of that truck, crew cab, single rear wheels, 6 speed manual trans. I pull a 5th wheel camper that weights about 11K pounds loaded and I would not want to go too much more than that. I would not think of pulling more unless I had dual rear wheels.
My truck weights more than 7,250 pounds empty. If the one you are looking at is comparable, your gross combined weight will be well over 20K. That will likely be over the rated CGVW weight (note other peoples points about saftey and insurance) and too much for the 7.3L Powerstroke, 3.73 ratio and automatic transmission to pull reliably.
Dozerboss
09-13-2004 21:16:45
 Re: OT. Ford Pickup in reply to Tim B, 09-13-2004 19:38:32
The camper is a whole differant animal than equipment hauling because of its high profile. Much more wind resistance and the sides are closed, so the draft from 18 wheelers pulls on your RV and the wind pushes you around. Basically your pulling a slightly rounded box.
The open bed equipment trailer doesn't have the same air drag. I would agree the 4:10 axle is better for take offs, but after that it loses to fuel economy. 3:73 is enough gear to haul, unless your climbing a mountain on a regular basis, then you'd be better off with the 4.10. I wouldn't pass on the truck if that was the only factor.
Insurance companies will look for outs if they have to pay. If the truck is properly licensed for the weight it carries, they would have to pay in the end. You can license a truck over it's GVWR and it's best to figure heavy. Even if the total load is over the truck GVWR the trailer is carrying the bulk of the weight and only the weight at the hitch counts toward the trucks gvwr. Thats a difficult calculation to make and prove in a dispute. That all depends on how the tractors are loaded and if it's a long trailer it's possible to put their weight mostly on the axles. The downside is that makes for sway, more fish bite and bucking on rough roads. The only true way to know if your exceeding GVWR would be to weight the load at the hitch, the truck and the cargo. The gvw is an estimate. If Jerry lives in a no fault insurance state or got in an accident in one, their paying--period.
PS
09-13-2004 19:44:35
On the otherhand, if there is a good reason why the truck has such low miles (e.g., he used it only to pull a camper a few times) I think that would be a good price. I love my truck, I have the 3.73 gearing, I consistently get 17 mpg plus.
If you could be by pulling less weight, it would be a nice truck to have.
Regards,
Tim B
Everett
09-13-2004 18:15:31
The gear ratio is too high. It should have a 4.11 gear to pull any thing that heavy. Forth gear should be overdrive.At least thats the mine is.
Jonboy
09-13-2004 17:54:35
Ford 350??, and ford didn't make a 5.4L diesel either. Being a 1999, it must have a 7.3L diesel, because that was the only diesel engine size availible. The 5.4L is a gasser thats in between the old school 302 (5.0L) and 351 (5.8L)engines. I don't know much about them, but I'd say 12,000lbs, plus the weight of the trailer would be too much for a 3/4 ton, especially for long hauls, like therealron already pointed out, you need to check the specs on the metal tag that you'll find when you open the drivers door. A 1999 with under 10,000 miles on it leads me to believe the truck must have gotten smashed and somebody just barely got it rebuilt. If it has the 5.4L in it, you might go to a dealer and see what a new compairable truck with the same engine gets, if it's a diesel, then a new truck will be equipped with a 6.0L diesel, as the 7.3L has been done away with, so you can't really compair them. Hope this helps,
TheRealRon
09-13-2004 17:32:54
I think you need to learn it's GVWR and then weigh the truck, trailers, and tractors and when you add them up you'll see you are at least 5,000lb overweight.
Jerry Cent. Mi.
09-13-2004 17:39:03
 Re: OT. Ford Pickup in reply to TheRealRon, 09-13-2004 17:32:54
Sorry about the first post I am told that its 7.3 cub's. Jerry
Dozerboss
09-13-2004 20:12:06
 Re: OT. Ford Pickup in reply to Jerry Cent. Mi., 09-13-2004 17:39:03
That's a Ford Powerstroke diesel, All are turbo diesels and it has to be a superduty to have one. A 3/4 ton is an F-250 superduty and an F-350 is a one ton. There's not much differance in GVWR between the 2, even the dual wheel models. You can't get the diesel in the lighter truck. 1 ton and under are considered light duty trucks.
This is my experience: A single rear wheel 3/4 ton superduty Powerstroke diesel will pull that weight with a gooseneck trailer. There are goosenecks rated up to 10 ton-20,000lb GVWR (thats trailer and cargo weight). (funny how they make trailers and hitches that will exceed the vehicles GVWR when loaded.) The highest rated receiver hitch is 14000lb with weight distribution bars for the truck, i know of. Reese makes a rail mounted goose that's rated for 26,000lbs, there's no hole to cut in the truck bed and the rails also accept the fifth wheel RV hitch. When you add the trailer weight and tractors to the truck weight you should be over the gross weight rating. If memory serves with a goose or fifth wheel hitch the GVWR is 22,000lbs for the Superduty. You will need skill to handle the load just like an OTR 18 wheeler needs to handle his rig. The engine will handle the weight no problem. Problems you will encounter are with braking and over heating the transmission in summer unless your in a cold climate. You can overcome them by adding an exhaust brake and extra cooling for the transmission-a bigger cooler and deeper pan. If you do it, Consider the exhaust brake as essential, whether you choose a low cost electronic unit that uses the existing engine cold start exhaust valve or the more expensive add on unit. The trucks factory brakes will be fine for normal traffic, but not for panic stops if someone fails to yield or for mountain driving. You need an exhaust brake for those situations.
All the triple axle 3 car haulers pulled by 3/4 and 1 ton trucks you see on the road are exceeding the GVWR. They can do it by modifying the truck, Having an extra cab and longer frame, distributing the weight with the extra or heavier duty axles and goose/fifth wheel hitching. The larger 32' and up fifth wheel RV's are right at or slightly over the GVWR of 3/4 and 1 ton trucks.
You can pull the weight with the right trailer with that truck. Whether you should is up to you, but for the sake of everyone on the road you shouldn't unless you up grade the brake system and have working trailer brakes.
There maybe a license issue, depending on the gross weight and if you exceed 26000lbs you may need a class B. It depends on your local DMV. I have never gotten a clear answer from mine. You can't pull for hire and exceed 26000lbs, then you need a CDL but you can move your own equipment and exceed 26000lbs. How much hassle you get, if any, from transport police depends on where you live. In my area they leave Farm and car haulers alone and focus on 18 wheelers as long as your load is properly binded. You need chain binders for that weight. Try to find out about licensing before you buy.
Guessing from the size trailer your going to need to haul 12,000 lbs and the truck's weight you should be under 26000lbs. A 10 ton goose is about 5500lb, the truck with cargo about 7500-8000lbs plus your 12000 in tractors. Over the stock GVWR but legal for private use, same as an RV.
The word is the newer 6.0 powerstroke diesels aren't performing as well as the big block 7.3's do.
Allan in NE
09-13-2004 18:14:12
Jerry,
LOL! Glad you caught that one; I was biting my tongue on the engine thing. :>)
Seems a little on the spendy side, but some would say that under 10K miles, same as a new one. I assume it is a 4x4 @ that kind of money?
If you take it somewhere and put it up on a lift, you should be able to see if it's been smacked.
I've got a low-mileage GMC Yukon that took a kiss in one front corner before I bought it; but it is still one of the nicest rides I've ever owned even if it has been hit.
Oh, and I dunno 'bout that "two tractor" thing either. :>)
Good luck on your decision,
Allan
Jonboy
09-13-2004 18:30:14
 Re: OT. Ford Pickup in reply to Allan in NE, 09-13-2004 18:14:12
This'll pull his tractors around!.
Ray
09-13-2004 18:37:04
 Re: OT. Ford Pickup in reply to Jonboy, 09-13-2004 18:30:14
Not impressed with the international,my duramax
has a lot more power and the same tranny.
Jonboy
09-13-2004 18:51:09
 Re: OT. Ford Pickup in reply to Ray, 09-13-2004 18:37:04
No, I wasn't really impressed either, thats a big truck for just 220hp, plus it's looks don't impress me much either, it's basically a dumptruck with a Ford dually pickup box on it, and the box doesn't look like it was made for the truck so it doesn't look good to me. I wonder if they are going to sell many?. I believe I heard a price of $85,000 or something on the news tonight, and you could buy a couple of nice one tons for that, with like you say, more horsepower, and basically the same thing, and I'd think a big truck like that would really be hard on the fuel.
Leland
09-13-2004 18:04:40
Still you are to heavy even with the 7.3 you really need a F350 better brakes and dual tires spread weight out better. F250 ok for onr tractor 2 is pushing lack of safety to the max. Besides ask your insurance what happens if you have an accident and you are past GVW, your screwed!!!
evielboweviel
09-13-2004 17:52:11
sure sounds cheap low miles for 5 years old
if it checks out good then you got a great deal and a good pulling truck
Ron
Jerry cent. Mi.
09-14-2004 13:59:03
 Re: OT. Ford Pickup in reply to evielboweviel, 09-13-2004 17:52:11
I bought it. 9965 actual miles & runs great. About $600.00 body work if I want to. Dings caused by 88 year old deceased driver. I feel good.
evielboweviel
09-14-2004 18:34:49
 Re: OT. Ford Pickup in reply to Jerry cent. Mi., 09-14-2004 13:59:03
sounds like you got a great deal enjoy it
Ron
