Tractor Talk Discussion Forum
seized AC B
Henk
09-13-2004 16:24:08
It never fails I restored an AC B and last saturday my boys drove it as usual and got her all shiny for the local fair.Then on sunday we were ready to go to find out that she is all seized up there was enough oil in here and the starter is not stuck what could it be and how to fix it.Thanks for any information.
evielboweviel
09-13-2004 16:39:57
 Re: seized AC B in reply to Henk, 09-13-2004 16:24:08
first pull all the sparkplugs out and see if it will turn over.
Ron
Nebraska Cowman
09-13-2004 16:42:28
 Re: seized AC B in reply to evielboweviel, 09-13-2004 16:39:57
good idea. could be one of the cylinders is full of gasoline or water.
Mark - IN.
09-14-2004 03:54:43
 Re: seized AC B in reply to Nebraska Cowman, 09-13-2004 16:42:28
If you're going to try pulling it in gear (3rd) to see if the engine turns over, pull those plugs first. If a cylinder(s) have fluid (water, etc) in them, and the fluid has nowhere to go, it will hydraulic at the cost of a connecting rod. Was it running when it "seized"? What is seized? Are you saying the motor won't turn over (budge)? Are you saying motor will run, tractor won't budge when release the clutch in gear?
What happened? Engine quit, lost oil pressure and knocked like crazy until quit? Valve stuck and slapped a piston? Had no coolant and seized? Engine runs, tractor won't move? brakes won't release because someone has the brake handles locked (locks at base of both handles flipped down). If engine runs but won't budge forward after releasing the clutch, try reverse to free up the shoes/linings if has been setting.
No matter what you mean by "seized", it's probably best to do with the tractor not running so don't cause any/more damage. Rock it, pull it, whatever.
Guess most important is what you mean by "seized". Under what exact conditions is it "seized"? Try to start/turn over? Move? At what point does it fail?
Mark Krzyzanowski
Nebraska Cowman
09-13-2004 16:39:39
Well I guess you'd better figure out whats wrong. Have you tried putting it in high gear and rocking it? Check for things like being in two gears or a brake stuck, clutch stuck etc. If it were not getting oil it should have told you when it was running. Try turning the engine both ways. If it is realy stuck I'd pull the pan and see if the crankshaft bearings were getting oil.
