Tractor Talk Discussion Forum
JD 4020
Doug Rogers
09-13-2004 05:33:21
I see advertisements for John Deer 4020s showing the horsepower as being 90 or 95 or 100 horsepower. Even from the same year. Is this right? I would have thought that they would all have the same horsepower ratings.
JMS/MN
09-15-2004 11:48:32
 Re: JD 4020 in reply to Doug Rogers, 09-13-2004 05:33:21
Depends how the injector pump is set. My'67 that I bought in '72, after overhauled, was rated 94 but cranked 110 on the dyno. Ran that way with no problems for many years. Had 8700 hours when I traded it for a 4430.
RAB
09-13-2004 08:59:49
Remember also that advertising hype around that period may well have meant power at flywheel being thrown around, rather than pto power.
Regards, RAB
Indydirtfarmer
09-13-2004 07:04:51
As previously mentioned, they vary with gas/diesel/lp/powershift/syncrorange/ect. When the 4020 was introduced in 1963 (as a '64 model) it was 91 HP ((powershift diesel) In 1966, it recieved a few minor updates. Power rating was increased to 94 (?). Then in 1969, they stepped it up to 96HP. Most were actually closer to 100. John
rustyfarmall
09-13-2004 06:00:37
If I remember correctly, the 4020 was rated at 90 horsepower from the factory, but the vast majority of them would run closer to 100 as delivered.
Jon H
09-13-2004 06:04:06
 Re: JD 4020 in reply to rustyfarmall, 09-13-2004 06:00:37
There were different HP ratings depending on gasoline,propane or diesel engine and if equipped with syncrorange or powershift trans.
rustyfarmall
09-13-2004 06:52:28
 Re: JD 4020 in reply to Jon H, 09-13-2004 06:04:06
I forgot about that, the power shift did seem to eat up quite a bit of power.
