Tractor Talk Discussion Forum
OT-anti freeze question?
300 Randy
09-07-2004 05:43:07
Can you use that 100,000 mile antifreeze in a vehicle that now uses regular antifreeze? Would be nice if I never had to change the antifreeze ever again.
T_Bone
09-07-2004 20:10:09
 Re: OT-anti freeze question? in reply to 300 Randy, 09-07-2004 05:43:07
Hi Randy,
You didn't say what your going to use it in. That makes a huge difference.
Zerex Go-5 is 5yr 100k for diesels with no SCA testng required. Ford used it since 2002.
T_Bone
ed1
09-07-2004 13:38:32
I�ve been told to stay away from the pink stuff in sleeved diesel engines as it promotes the pinhole effect in wet sleeve engines. One day you�ll check the oil only to find what appears to be milk - oil & water mixed together. The reason tiny holds drilled in the bottom of your sleeves.
You want to use only the green stuff with an additive. I�ve also heard that adding a water filter can also help.
Ed1
John M
09-07-2004 12:47:33
Ya gotta flush it good,maybe 20 minutes maybe longer..... ...You can mix it but it doesnt cause the problems people think,it mearly looses its extended life capabilties.I make the stuff,well for now anyways!
Bus Driver
09-07-2004 10:09:29
I spent almost $1000 to replace the water pump on a 1994 Chrysler product shortly after I used one of the long- life anti-freeze solutions in it. The seal failed. Now I use the long-life products only in vehicles that very specifically mention approval of the use of the long-life. No more Chrysler stuff for me either. There are no honest dealers in my area for those brands.
FarmerDave
09-09-2004 15:17:56
 Re: OT-anti freeze question? in reply to Bus Driver, 09-07-2004 10:09:29
I think the statement about no honest Chrystler dealers could be shorted to no honest dealers. Oh sure,, you'll have good luck with a dealer 20% of the time.
Allan in NE
09-07-2004 10:20:39
BD,
Bet I know what you drive! Isn't that just about the smartest set-up yet?
Haveta pull the tranny to change a water pump. Geeeze!
Who was the knuckle-headed engineer that dreamed up that one anyway?
Or, like the high end GMs with starter mounted inside the engine. Go figure.
It�s no wonder we like old tractors!
txblu...feelin scrappy
09-07-2004 09:09:22
Tabood subjects: Religion, Politics, oil, anti-freeze.
Allan in NE
09-07-2004 09:34:51
 Re: OT-anti freeze question? in reply to txblu...feelin scrappy, 09-07-2004 09:09:22
Hmmmm,
Let me understand this, just so I don't make any mistakes here.
So, say if I were to say something to the effect that President Bush's belt size is four times larger than John Kerry�s here-to-date demonstrated IQ level, then this would be considered to be in poor taste?
thurlow
09-07-2004 09:53:00
 Re: OT-anti freeze question? in reply to Allan in NE, 09-07-2004 09:34:51
No, no, no; you don't understand.....what does that have to do with Religion, Politics, Oil or Anti-freeze????? Belt sizes/IQ.....perfectly acceptable..... .
txblu
09-08-2004 05:42:49
 Re: OT-anti freeze question? in reply to thurlow, 09-07-2004 09:53:00
Yeah!
Allan in NE
09-07-2004 10:06:31
ROFLMAO!!!!! !!!!! !!!!! !!
txblu
09-08-2004 05:43:24
 Re: OT-anti freeze question? in reply to Allan in NE, 09-07-2004 10:06:31
Allan in NE
09-08-2004 05:56:19
 Re: OT-anti freeze question? in reply to txblu, 09-08-2004 05:43:24
Rolling on the floor, laughing my a$$ off.
txblu
09-08-2004 09:58:10
 Re: OT-anti freeze question? in reply to Allan in NE, 09-08-2004 05:56:19
Ok. Thanks,
Mark
TheRealRon
09-07-2004 07:26:40
DEX-COOL is a great product. It's now a 150K change interval. Of course you can use it in an older (pre '95) vehicle that was not a factory fill.
However, you cannot mix DEX-COOL with green coolant. So you must flush the entire cooling system for 20 minutes with a garden hose. This includes the recovery jar. Then fill with DEX-COOL and DISTILLED water.
You will hear from some that DEX-COOL caused problems. This is wrong. All so-called DEX-COOL problems are caused by either...
1) Allow a cooling system to leak and not keeping it topped off until the leak can be corrected.
2) Many people who don't know any better top-off the recovery jar with green coolant because they are too ignorant to read the DEX-COOL warning label under the hood. If they are ever mixed, the entire system must be flushed per the instructions above. If you allow others to service your vehicle, you can buy the warning sticker from any GM dealer.
Mike M
09-07-2004 09:56:15
 Re: OT-anti freeze question? in reply to TheRealRon, 09-07-2004 07:26:40
DEX-COOL is not anywhere near as good as the claims. Talk to any GM tech. and then talk to the people who run the extended warranty companies. They can tell you horror stories.
txblu
09-07-2004 09:07:13
Well I guess my radiator in my '98 Dodge is going to fall off. Have been mixing for the last several years.
Mark
buickanddeere
09-07-2004 11:38:03
 Re: OT-anti freeze question? in reply to txblu, 09-07-2004 09:07:13
If Dex Cool is exposed to oxygen from a faulty rad cap etc. It will decompose in short order.
txblu
09-07-2004 11:39:26
 Re: OT-anti freeze question? in reply to buickanddeere, 09-07-2004 11:38:03
Allright. I'll keep a watchful eye. Thanks for looking out for me.
Mark
Mike M
09-07-2004 06:54:52
Don"t do it !! GM has used this since mid 90"s marketed under DEX-COOL this stuff is a joke it will plug up faster turns to mud fast and eat up your water pump seals.And belts once it leaks on them.
buickanddeere
09-07-2004 06:46:45
For non poisonous antifreeze that won't kill pets, wildlife and kids use propylene glycol instead of ethylene glycol. About the same price too. Won't ruin bearings if some leaks into the crankcase as well. Long life or not, test the coolant with a ph test strip yearly. A slightly seeping head gasket etc will turn new coolant acid in short order. Of course mix with distilled or demineralized water. Tap water always contains disolved minerals that will plate out in the cooling system and affect the ph of the coolant.
Leland
09-07-2004 05:45:54
You can but flush system good, you can mix but it shortens life down to 75000 miles or less.,
txblu
09-07-2004 05:43:58
I do.
steveormary
09-08-2004 15:01:37
 Re: OT-anti freeze question? in reply to txblu, 09-07-2004 05:43:58
Other stuff not to argue about. Wimmin and water. In the south of NM they say more men have been killed over water then over wommen.
steveormary
