Tractor Talk Discussion Forum
magneto on AC
Henk
09-06-2004 12:43:51
Could anyone advice me on how to set a magneto for an AC B
Rod (NH)
09-06-2004 13:17:30
 Re: magneto on AC in reply to Henk, 09-06-2004 12:43:51
Hi Henk,
Assuming you have the FMJ magneto:
Magneto Internal Timing
Magneto to Engine Timing
Make sure you are on the compression stroke for #1 cylinder. The flywheel marks are visible through the 1" diameter opening on the left side of the torque tube. Number 1 TDC is indicated by "CENTER" appearing in the middle of the hole. The advance spark position is indicated by "FIRE" appearing in the center of the hole. Use "FIRE" for method number I and "CENTER" for method II.
third party image Rod
