Tractor Talk Discussion Forum
1936 C Case
Justin Heinze
09-05-2004 17:56:32
I have a 1936 C - Case. I cant figure out how oil is supposed to get to the rocker arms and valve stems. CAN ANYBODY HELP
Brian in Ohio
09-06-2004 10:58:23
 Re: 1936 C Case in reply to Justin Heinze, 09-05-2004 17:56:32
I have a 36 C myself, and all of the previous posts are correct as far has you have to oil the rockers and valve manually.
What is the serial number is your tractor? (Looking to see how far down the line yours was built from mine)
George G
09-06-2004 09:13:19
Here's what the manual say's.( It is recommended that the valve cover should be removed every two or three weeks and kerosene squirted around the valve stems while the engine is running. Then oil all valve mechanism with fresh light oil.) If mine has been setting for a while. I pull valve cover and oil before starting. And then about every eight hour's operating time.
Scott KY
09-05-2004 19:22:05
I believe you have to remove the cover and oil them manually. I think it is required daily. Maybe someone else can correct me if I am wrong.
Texas Red
09-06-2004 03:39:48
 Re: 1936 C Case in reply to Scott KY, 09-05-2004 19:22:05
Yes, that is the way you have to keep the rockers oiled. I have a 35 CC-4 I have to oil it every tine i crank it . TR
OGGIE
09-11-2004 19:23:26
 Re: 1936 C Case in reply to Texas Red, 09-06-2004 03:39:48
Take on old blue jean pants leg and soak it in oil then fold it to fit on top of the rockers and under the cover. This will keep them oiled for at least a week.
