Tractor Talk Discussion Forum
Case IH 1594
Willy
09-03-2004 06:12:06
The Case IH 1594 I have is putting fuel out the exhaust. I removed the exhaust to see which cylinders the fuel was coming from, The fuel is coming from all 6 of the exhaust ports. When I checked the temperature of the exhaust while the engine was running, # 5 & 6 were up to temp but the rest were maybe about 30%. I removed and sent the injector out to be tested - all are ok. I removed the cylinder heads thinking the valves were bad but all valves and piston ring are good. I am unsure what to do next, I am thinking maybe gear/pump timing but the temp on #5-6 are making me think.
Allan in NE
09-03-2004 07:25:56
 Re: Case IH 1594 in reply to Willy, 09-03-2004 06:12:06
Willy,
Was it really only running on just 2 cylinders or was it hitting on all 6? Can't believe it would run on only 2.
If it isn't missing, probably nothing wrong with it and it is just slobbering out the exhaust due to "putzing' around at low speed like all diesels do.
Allan
Willy
09-04-2004 06:58:53
 Re: Case IH 1594 in reply to Allan in NE, 09-03-2004 07:25:56
Allan the engine is missing and hard to start.
TheRealRon
09-03-2004 06:40:13
Before going through all that work I would have run a compression test. If I were a betting man I would bet the compression is way low on 1-4.
