Tractor Talk Discussion Forum
Kohler 321 lack of power
Tat
08-27-2004 06:22:58
I just put a piston and rings in a Kohler 321 in a Toro Tee Mower, The motor runs and sounds great till you engage the mowers, then its spitting and sputtering and wont even pull itself ?
JT
08-27-2004 06:35:12
 Re: Kohler 321 lack of power in reply to Tat, 08-27-2004 06:22:58
sounds like You need to either set your timing on your points, or the carb needs to be set a little richer.
Tat
08-27-2004 06:38:11
 Re: Kohler 321 lack of power in reply to JT, 08-27-2004 06:35:12
I did adjust the carb but have not done anything to the points ?
Tat
08-27-2004 07:56:44
 Re: Kohler 321 lack of power in reply to Tat, 08-27-2004 06:38:11
Where are the points located on the 321 ?
Dr.EVIL
08-27-2004 08:43:16
 Re: Kohler 321 lack of power in reply to Tat, 08-27-2004 07:56:44
Little metal cover below the carb. and exh. port on the block. There's a cover held on with four capscrews over the timing gear and it's right next to that cover, held on with two small machine screws, one each at top & bottom.... Should have a small wire coming out the bottom corner.
Bob
08-27-2004 08:57:44
 Re: Kohler 321 lack of power in reply to Dr.EVIL, 08-27-2004 08:43:16
He"ll look hard and long for those points, if it turns out he has electronic ignition on his engine!
Dr.EVIL
08-27-2004 13:24:28
 Re: Kohler 321 lack of power in reply to Bob, 08-27-2004 08:57:44
If He has electronic Ignition I doubt He even HAS points. The complete Kohler service manual is avail free on-line at Kohler.com. Takes forever to download. I've started three-four times but always stopped. I have a hardcopy at home.
Tat
08-27-2004 08:44:37
Thanks, I"ll set them to .020 tonight.
