Tractor Talk Discussion Forum
gear noise/gear lube
n8terry
08-25-2004 15:45:47
Will heavier gear lube quiet gear noise on my parade tractor? will 85/140 help?
Allan in NE
08-25-2004 16:32:05
 Re: gear noise/gear lube in reply to n8terry, 08-25-2004 15:45:47
Hi Terry,
My H had the typical gear whine when I got it here. It seemed a little louder than it should to me, so I swapped out the oil to the heavier stuff.
Didn't make a lick of difference on mine; maybe the gears had went too long running against each other between oil changes, I dunno.
A little whine is a normal thing even on the newer planetary types.
The other day, I was at the local TSC store and a fellea was in there with his "Like New" 986. I noticed it whining as he pulled away.
All you can do is try it, I guess.
Allan
