Tractor Talk Discussion Forum
Stroke
Martin
08-22-2004 14:59:51
I have heard engines described as 2 stroke, 4 stroke, and sometimes even 7 stroke, what does this mean?
Allan in NE
08-23-2004 09:07:15
 Re: Stroke in reply to Martin, 08-22-2004 14:59:51
Well Okay then,
How many strokes would you define a hit/miss engine? :>)
Allan
Martin
08-23-2004 09:55:01
 Re: Stroke in reply to Allan in NE, 08-23-2004 09:07:15
I hear hit 'n miss engines are 2 stroke, the 7 I mentioned is actually a radial engine, anyway, thanks everyone for you replys!
wilson
08-22-2004 19:51:40
There is an 8 stroke which is really a 4 stroke with 2 rounds valves open for air cooling Its weird and I have only seen 2 of them at shows
Hugh MacKay
08-22-2004 19:26:32
Martin: I think you have been given very good descriptions on the 2 and 4 stroke cycle engines.
I'm kind of curious where you heard of this 7 stroke engine? I'm not trying to poke fun, just curious. I can maybe see that applyng to a radial engine.
MMB
08-22-2004 18:29:11
Actually, every "stroke" is one-half of a full revolution of the crankshaft, for example a 4-stroke engine is really two full revolutions of the crankshaft .... the intake is one-half of a revolution, followed by the compression, followed by the power stroke (after the fuel/air mixture is ignited), followed by the exhaust stroke. In a 2-stroke engine, things are generally condensed somewhat with a lot of overlap. The first stroke (1/2 revolution) combines the last power stroke with an intake stroke (of the next sequence), while the second stroke (1/2 revolution) combines the last power stroke with the next intake stroke. Two stroke engines are usually less efficient with their exhaust emmissions being somewhat less environmentally friendly since less of the fuel being delivered into the system gets totally burned during the power stroke (and is into the exhaust of the exhaust stroke). That's the reason why so many lakes, etc. ban 2-stroke boat engines since so much unburned fuel is expelled into the water.
720Deere
08-22-2004 15:33:43
A Four stroke engine makes 4 piston strokes for every complete cycle. 1. Intake 2. Compression 3. Power 4. Exhaust
Two Stroke engines combine the intake/power strokes and the compression/exhaust strokes.
Joe (Wa)
08-22-2004 15:27:51
Internal combustion engines have four evolutions:
Intake, compression, combustion, and exhaust. Depending on the design of the engine this can be accomplished in either two or four piston strokes I.E. 2 stroke cycle or 4 stroke cycle.
