Tractor Talk Discussion Forum
1950 era trailers
Neil Frisch
08-21-2004 12:21:00
I have a 1959 f750 dump truck tht I am restoring. I am about to get a 1556 ford tractor. I want to get a 1950s era trailer to pull the tractor behind the truck. can anyone share some info about trailers from that time span? Who made them what did they look like? I probably will build one from sctratch, but I would like for it to look authentic.
Paul Janke
08-21-2004 21:10:38
 Re: 1950 era trailers in reply to Neil Frisch, 08-21-2004 12:21:00
In the early 60"s I was quite young yet, but it seems like the county used a tandem dual tilt bed trailer. It didn"t have the hydraulic cylinder to slow down the tilting like the new trailers. I would guess the tires were lowboy 15", maybe 8.25"s or 9.00"s.
J.C. IN AZ.
08-21-2004 19:53:18
In N.C.Ill. in the 1950's the Implement Dealers were about the only ones who hauled any thing on a trailer and it was usually a 10-12ft. long by 8ft.wide tilt bed made from a two ton truck rear end.It may or may not have had a winch and if it did a hand operated one was the usual norm. Not much power assist like Hydraulics etc. Farmers drove their Tractor and Machinery to where it was to be used. This was not a big problem as they mostly had 160 -320 acres in one Block of the Section and road travel wasn't done. We did not have a Trailer to haul Machinery on our 280 acre Dairy Farm but had a variety of 4 wheel wagons with one 2 wheel feed wagon and two 2 wheel Manure spreaders.I remember some of these trailers which were Factory Made were Fruhauf Trailers. Road Contractors of course had Low Boys to haul their Construction Equip. on.
john in la
08-21-2004 13:52:49
I sure hope the only thing authentic about this trailer is the look. To say the least they were not the safest things I"ve seen at least by today"s standards.
how about
08-21-2004 13:12:46
an old Air Stream. Modify the rear for a power lift to open it up and a power lift to load your tractor with. A few logos on the side and you will be considered top of the line just like in the 50's.
KenSWLA
08-21-2004 12:46:15
I have seen a picture of a trailer John Deere used for tractors but don't remember the year. I will look through my JD literature to see if the picture can be found. The way I remember it was a flat bed trailer.
Allan in NE
08-21-2004 12:40:55
Hi Neil,
Are you talking about a semi-tractor trailer flat bed, low-boy, farm wagon or what?
Guess I'm not following you.
Didn't see many trailers drug up and down the road in those days; most folks hauled their tractors on straight trucks.
Allan
KX
08-23-2004 07:44:21
 Re: 1950 era trailers in reply to Allan in NE, 08-21-2004 12:40:55
I agree with Allan. I am too young to have seen it myself but I have seen pictures of 12 foot combines sitting on the back of IH, Ford and Chevy 2 ton flatbeds. I have been told most of the cabs were damaged on top from the header riding on the top of the cab. There is a old truck a farmer set up like that for a yard ornament near Wakita, OK I saw once. I dont remember what make truck but it has a Massey Ferg combine sitting on the back of it and a "Need Work" sign in the windshield. IF you saw a trailer in the 50"s, chances are good it was made from the bed of a old truck.
Neil Frisch
08-21-2004 12:22:34
 Re: 1950 era trailers opps in reply to Neil Frisch, 08-21-2004 12:21:00
My tractor was made in 1956 not 1556
