Tractor Talk Discussion Forum
Farmall M ID #
Paul Baes {PAU
08-21-2004 11:48:26
I have aFarmall M #16749 Block casting #4 425 W. The block has a plate covering a hole on the left side. Could this be for a fuel pump?I was told that the numbers are not correct. HELP; Thanks. PP.
John M
08-22-2004 07:23:44
 Re: Farmall M ID # in reply to Paul Baes {PAUL THE PULL, 08-21-2004 11:48:26
The 425W part is the casting code for when the block was cast.Yes,the plate was for a fuel pump,What you have is an IH repalcement engine.That engine was built for use in several different applications so IH put all the extras on it for whoever may need it for whatever they need it for.The part number for the engine has been ground off.Contact nme via email and Ill send you some pics of my M with the same engine on it.
08-22-2004 09:25:59
 Re: Farmall M ID # in reply to John M, 08-22-2004 07:23:44
John M.Thanks for the info.
Do you know the cu. in. of this eng?
John M
08-22-2004 15:22:57
 Re: Farmall M ID # in reply to Paul Baes {PAUL THE PULL, 08-22-2004 09:25:59
MINE is the regular 247.I do know of one that was the 264.I have only seen a few of these engines.
