Tractor Talk Discussion Forum
CIH 2250 loader on CIH 885 4x4 tractor
Kraig
08-16-2004 16:04:15
Does anyone know if a CIH 2250 model loader will fit on a CIH 885 4x4 with cab tractor? Thanks.
Scott KY
08-17-2004 18:54:48
 Re: CIH 2250 loader on CIH 885 4x4 tractor in reply to Kraig, 08-16-2004 16:04:15
I don't think it will fit a cab tractor. It mounts to far back and will interfere with the cab. Double check to be sure.
K.B.-826
08-17-2004 18:16:05
Probably, but you need to check if mounts are avalible for your specific tractor. A Case-IH dealer could tell you that. I know I've heard of 2250's on 884 and 885, just don't know if your cab makes a difference. Whatever you do, don't buy mounts unless you are 100% sure they are for your tractor. We once traveled a long distance to buy a 2250 for the 706. Those mounts sure looked right, but when I started to put them on, it quickly became obvious that they were not. Took a bit of modification.
Bernard le mécano
08-18-2004 06:49:19
 Re: CIH 2250 loader on CIH 885 4x4 tractor in reply to K.B.-826, 08-17-2004 18:16:05
Hi, the 2255 is the loader for a 885 4x4 XL cab. With a 2250, the front wheel are to close of the lift cylinders. Bernard le mécano Québec Canada
