Tractor Talk Discussion Forum
haywagon deck protection
Farmer in the D
08-15-2004 08:25:26
What do you use to protect the wood deck on your haywagon? It will be stored undercover so UV is not the question, but when left out moisture is my issue. What product(s) can I use that will protect the wood and not harm the animals when I use it to collect hay? Water seal, paint, stain? What is working for you?
kyhayman
08-15-2004 16:47:54
 Re: haywagon deck protection in reply to Farmer in the Dells (WI), 08-15-2004 08:25:26
All mine have 1-1/2" thick x variable width x 8' rough white oak for flooring spaced 3/4" between the boards when built. Flooring nailed to 3"x10"x20' runners, with 2"x6"x20' side rails. Normally soak the runners and ends of the flooring where the wood touches wood with used oil, otherwise just leave them be. I store them outside in a humid climate and normally get at least 15 years out of one. Some folks that buy some from me want them painted, when I do I use black acrylic fence coating. Seems to do ok. I have one painted one (guy backed out on the sale). Built it in '91 and still seems ok, seems like it wears about even with my unpainted ones. My cost to build one is a shade over $300. At 15 years thats $20 of depreciation a year. Based on the way the paint wears off, seems like it would take that much time and materials to keep one, would defintely cost me more than that to lose the storage space in the barn to keep it inside.
Leland
08-15-2004 13:12:56
I agree with bob ,linseedoil or used motor oil will protect them for years.
520-LP
08-15-2004 11:42:56
I just got a 20ft 4 wheel wagon bed done using metal runners and pressure treated cross sills with a pressure treated 2X6 down the outside,then floored with 3/4 plywood,then painted the plywood John Deere Green [use your choice of color] after applying the second coat of paint while its still wet cover with a light coat of dry sand,sweep off the excess when it drys ,makes a good rough surface.
UFO Man
08-15-2004 11:21:00
Bob, If it was me, I wouldn't put anything on it. Even if it is outdoors for a rain shower, the wood won't pick up enough moisture to hurt it if you allow it to dry. Keeping it under shelter will be all the protection it needs.
If you have to do anything, paint it with exterior grade paint, priming correctly will keep it from flaking. Amimals can eat paint chips without harm since there isn't any lead in paint anymore. Latex is just an inert substance when it dries and passes through their gut.
I prefer a rougher texture surface on hay wagons or hay hauling trucks. Hay particles are slick enough to keep your footing on without adding a slick surface underneath.
A few years ago, I was helping a neighbor put up his hay. His son driving the pick up, he was on the ground throwing to me in the back of the truck. He had a full bed liner in the truck. The truck hits a bump, my feet go straight out in front of me, my butt hits the top of the bed and I flipped out onto the ground, landing on my head and shoulders. Luckily, I just kept rolling avoiding the trailer that we were pulling. But since I've gotten a bit older, I don't enjoy getting dumped like that anymore.
Hope this helps.
UFO Man
Van(WA)
08-15-2004 11:18:04
BOB; I would go with what your dad did. I know of no product that is superior, or will last as long., and you can add a oil base stain for color if desired.
Bob
08-15-2004 10:17:34
When I was a kid, Dad painted them with boiled linseed oil.
