Tractor Talk Discussion Forum
workmaster or not
michael
08-08-2004 16:51:07
I just got a new/old tractor and the decals say 601 workmaster. The serial#is 640 on top and 144727 under that, also EAE 6015-J could this be a workmaster? This is very confusing to me.
Jim.UT
08-08-2004 20:35:41
 Re: workmaster or not in reply to michael, 08-08-2004 16:51:07
Based on the numbers you give I would say "not". Here's the story: 640 means it's a model 640 of the 600 series. Your serial number says it's 1957. The EAE-6015J casting number means it has a 134 cu in overhead valve 4 cylinder engine (correct engine for a 640).
In 1958 (starting production in late '57) the 600 series was replaced by the 601 series. There were a few minor upgrades....a couple more hp, slightly higher compression ratio, but basically the same tractor; except they started painting them all red except for gray grille and fenders. Also they gave the 601 series a fancy name "Workmaster". My guess is someone slapped a newer Workmaster decal on the hood to make it appear newer for resale. What color is your 640? It should be gray (sheetmetal) and red (castings) like a Jubilee.
I have heard pretty reliable stories of some 800 series Fords in late '57 getting the newer "Powermaster" decals intended for the 801 series right from the factory. I've never heard the same about Workmaster decals being put on late '57 600's, but I suppose that is another possibility.
There are some date codes on your tractor that would help you narrow down the build date of the tractor. I don't know exactly when in '57 the 601 and 801 series began production.
Here's a link to a site that you may find useful. Be sure to click all the red buttons for the full story.
