Tractor Talk Discussion Forum
Valve setting on 70 John Deere all fuel
Ron Schroeder
08-07-2004 09:21:12
What is the valve tappet setting on intake and exhaust valve of a 70?
Thanks
buickanddeere
08-07-2004 17:17:12
 Re: Valve setting on 70 John Deere all fuel in reply to Ron Schroeder, 08-07-2004 09:21:12
If the valve tips and rocker are tips have high & low spots worn in them. Setting with a feeler gauge can leave the lash wide & noisy. Try tightening the lash until spring pressure stops easy rotation of the push rod with your fingers. Back off 1/4 turn and tighten the lock nut.
TheRealRon
08-08-2004 03:58:23
 Re: Valve setting on 70 John Deere all fuel in reply to buickanddeere, 08-07-2004 17:17:12
Ignore this nonsense.
The proper way to set valve lash for any engine with followers or solid lifters is to use a feeler gauge and set it to the specs in the manual.
buickanddeere
08-08-2004 11:12:36
 Re: Valve setting on 70 John Deere all fuel in reply to TheRealRon, 08-08-2004 03:58:23
How does the realron measure across a curved contact surface with a flat gauge?
Mike M
08-08-2004 17:59:47
 Re: Valve setting on 70 John Deere all fuel in reply to buickanddeere, 08-08-2004 11:12:36
I don't know how the real ron does it but the real mike just pulls off the rocker arms and dresses up the faces with a grinder.
george md
08-08-2004 18:27:06
 Re: Valve setting on 70 John Deere all fuel in reply to Mike M, 08-08-2004 17:59:47
Mike ,
If they are too bad to just grind, build up with hard spray weld and grind. I have a rocker arm grinding attachment for a grinder , works nice.
george
buickanddeere
08-09-2004 06:29:38
 Re: Valve setting on 70 John Deere all fuel in reply to george md, 08-08-2004 18:27:06
Very few people dress the rocker arms true even when rebuilding the engine. For those who don't true the valve train up. The lash will be too loose when measuring with a flat feeler gauge over peaks and valleys.
george md
08-09-2004 08:45:41
 Re: Valve setting on 70 John Deere all fuel in reply to buickanddeere, 08-09-2004 06:29:38
b&d, Agreed,if rocker arm is not smooth then adjustment cannot be any where near accurate.
george
Mike M
08-07-2004 16:37:50
.020 hot or use .022 COLD for both
