Tractor Talk Discussion Forum
John deere 410 Hydralic problem
Lars Wessling
08-04-2004 14:24:32
Hello I have bought a JD 410.
It works fine but the backhoe is weak.
I can push and drag a big stone towards and away
from me, But it has trouble moving a small stone
sideways. I switched hoses with another cylinder(bucket) but it�s still weak so it�s not the gauges. Could it be the hydralic motor that
turns the backhoe ?
Thankful for ideas.
Best Regards
Lars
msb
08-04-2004 19:39:49
 Re: John deere 410 Hydralic problem in reply to Lars Wessling, 08-04-2004 14:24:32
If its like most control valves,each function has its own pressure relief valve.They are usually stamped on the end as to the pressure setting.Look like a big nut.You could have a weak relief valve on the swing valve.Some valves have two relief valves.One for extend and one for retract.
