Tractor Talk Discussion Forum
OT-car Results Thanks
tlak
08-03-2004 07:45:02
I checked the fuse-OK
I decided to change the thermostat and the $8 switch.
Test drive- blew a small cloud of black smoke initially and then not again. So I think its fixed. Check fuel mileage later.
The fan had stayed on, now it operates thermostaticly. I thought it had quit working but it was on by the time I got back from the test drive.
I was going to sort it out between the thermo and the switch but they were both in the same area and had to drain the radiator so I just changed both for $17.
I work from the cheapest on so having it serviced was the end of the line and not using passing gear was not an option.
Thanks to Everybody
RJ-AZ
08-03-2004 18:45:19
 Re: OT-car Results Thanks in reply to tlak, 08-03-2004 07:45:02
Always good to hear back from a post. Make us wonder sometimes if our advice did anyone any good. I bet that car wasn't going into closed loop. Hope your fuel mileage picks up. I run a pretty constant 28-30 mpg in a 93' 3.1 Lumina.
Vern-MI
08-03-2004 17:52:34
Thanks for the feedback tlak. I suppose if you wanted to know if the thermostat is working properly you could first examine it to see if it is stuck open. You could then heat it in a pot of water with a thermometer to measure the water temperature at which it opens. Glad to hear that the problem seems to be solved. Great site.
