Tractor Talk Discussion Forum
Which will run a NH 850 better
old
07-30-2004 21:24:05
I have a Farmall 450 and an Oliver Super 88 which tractor will handle the baler better and make the largest bales. Thanks for your oppions
James in NC
07-31-2004 06:13:24
 Re: Which will run a NH 850 better in reply to old, 07-30-2004 21:24:05
I would go with the 450.
Nebraska Cowman
07-31-2004 05:26:51
Changing the tractor will not change the size of the bale.
old
07-31-2004 12:29:35
 Re: Which will run a NH 850 better in reply to Nebraska Cowman, 07-31-2004 05:26:51
Well that isn't true, when I had a allis 190xt it would bale a 2500lbs bale and with the 450 its more like 15 to 1800 lbs. So if you use a bigger tractor you bale heaver but with the to I've asked about they are rated as being 55 HP. I'm just not sure if the fact that 1 is 6 cylinder will make any differance
steveormary
07-31-2004 09:41:37
old;
They are both about the same in hp. Try them out and go with whichever works the best.
steve
