Tractor Talk Discussion Forum
Trailer plow tires
Slofr8
07-28-2004 19:35:35
Hi, I just bought a Massey Harris 2 bottom trailer plow. One tire is real rotten and I have the wheel off to replace it. I intended to just put a used 16" tire but all the ones I find are much taller than the one I'm replaceing. One tire is going to be taller than the other. Is this going to be a problem? Can I use it this way, or should I replace both tires so they are the same size? Thanks, Dan.
rustyfarmall
07-29-2004 04:43:54
 Re: Trailer plow tires in reply to Slofr8, 07-28-2004 19:35:35
I don't know too much about a Massey Harris in general but I have found that 5.50 or 6.00 X 16" front tractor tires work out pretty well on my IH little genius 2-14s, although the land side tire I believe is supposed to be taller than the furrow tire. I have a couple of non-operating plows that are set-up with a 7.00-16 truck tire on the land side and use a smaller 16" tire on the furrow side. I also have an IH little genius 2-14s on steel, the land side wheel is larger than the furrow wheel, and I know it is original. The land side wheel being a larger diameter is to allow for more adjustment so that the first furrow you turn when starting a field will be at the same depth as the rest of the field.
Slofr8
07-31-2004 02:32:28
 Re: Re: Trailer plow tires in reply to rustyfarmall, 07-29-2004 04:43:54
Thanks rusty,
I called a local tire dealer and he was going to put aside a couple of used front tractor tires for me. Should work fine for my needs.
