Tractor Talk Discussion Forum
calcium cloride mix
Tractor dan
07-23-2004 18:25:27
i want reload some tractor tires with calcium cloride but the new bags of cloride dont have the chart on them like the old bags so im not sure how many pounds of cloride to mix up 50 gallons thank you
buickanddeere
07-26-2004 05:09:02
 Re: calcium cloride mix in reply to Tractor dan , 07-23-2004 18:25:27
What tractor, tire size, other weights, equipment mounted/drawn, soil type and the intended use(s)?
mike
07-24-2004 03:31:20
4 lbs of calcium per gallon of water will give you a 40 below zero mix. Make sure you add the calcium to the water as opposed to adding water to the calcium.
Ron
07-23-2004 22:00:55
See Link
Leland
07-23-2004 20:26:26
The shop I worked in used about 120 lbs in the tank so 50 gal water= 400lb +120 calcium =520lbs per tire if your tire will hold 50 gal hope this helps good luck
