Tractor Talk Discussion Forum
Long 360 Power steering
Rick
07-23-2004 09:20:55
The power steering feeds directly off the hydraulic pump which currently has gear oil in it. My manual says that the trans is supposed to have Multi-Purpose fluid in it. However the suction line for the pump is attached behind the trans in the differential housing. This is also where the dipstick is located and has gear oil. The trans is also full of gear oil. Is this correct? Does the trans carry gear oil and the defferential trans fluid. The manual says the hydraulic system runs on Exxon Torque Fluid 56 or Equivalent. What is this? And the Manual says the trans carries Multi-purpose fluid.?
Bus Driver
07-23-2004 16:26:21
 Re: Long 360 Power steering in reply to Rick, 07-23-2004 09:20:55
I believe that the 360 was made with two different power steering setups. Mine has a separate pump and reservoir for the power assisted steering. Mine can be steered with the engine off. The power steering cylinder has a hollow shaft that feeds the fluid to the back end of the cylinder. Your setup may be different. On the Orphans (Lesser Known Classics) board, Marv and Geo sometimes post and really know the Long tractors.
