Tractor Talk Discussion Forum
Kubota L-245
James Wade
07-21-2004 14:21:59
Need the torque spec for the head,the valve adjustments,and does the rocker arm need torqueing also? If so,do you have that also? Thanks!!! Im a newbie here...answer my question...maybe I can answer one for you!
Tommy D6-8U
07-22-2004 19:06:42
 Re: Kubota L-245 in reply to James Wade, 07-21-2004 14:21:59
James,
I'm still not sure about your head bolt torques because "m not sure which engine you have. The valve adjustments are 0.007" - 0.008" on both. The rocker arm support bolts/nuts are 12-15 lb-ft. The head bolts can range from 48 - 72 lb-ft depending on model number. If you can get me that I will more than happy to look them up for you on Monday (off till then). The engine number will be adjacent to the injection pump on a machined pad and will be DXXXX-XXXXX; the D is for a 3 cylinder engine. I think its an 1102 or 1302 engine but lets be sure. E-mail me directly if you want. Common mistake on Kubotas; be sure to install a new O-ring on the oil nozzle on top of the block at the left front. If you leave it out, it will leak!
Tommy
Tommy D6-8U
07-21-2004 17:44:35
James,
If I'm not mistaken, that's the D1102 engine in the L-245. I work at a Kubota engine dealer; I can get the torques tommorrow (the 22nd) if that's soon enough. I will post back to the thread.
Tommy
