Tractor Talk Discussion Forum
Ford 501 sickle 14-92
Jim
07-19-2004 18:31:50
what is the tie rod arm for on the 501? Where does it get hooked? What are the triangular steel pieces attached where the two pins are for the 3 pt hitch?
paul
07-19-2004 19:29:40
 Re: Ford 501 sickle 14-92 in reply to Jim, 07-19-2004 18:31:50
The tie rod arm has a 1 bolt clamp on the end of it, & it clamps to the left 3pt arm. Do this with the mower down on the ground. When you pick up the 3pt, the tie rod will pull the chain & raise the sickle bar.
Ford had several different clamp deals for different tractor models. If you are hooking up to a Ford tractor with good solid anti-sway bars, you probably will not need any such triangles. Without stablizers, they are to clamp on somehow to act as anti-sways.
A manual for the mower is only 10-15 bucks from New Holland, they have a 1-800 number for such things. Real helpful to sort this out.
--->Paul
