Tractor Talk Discussion Forum
??? trailer . . . . . . . Haul an M
Brad
07-19-2004 10:05:02
What kind of a trailer do you use to haul a Farmall M with a WFE?? GVW? M weighs 4500 lb.
What makes are to look for? Brakes?? Thanks
John S-B
07-19-2004 21:02:44
 Re: ??? trailer . . . . . . . Haul an M in reply to Brad, 07-19-2004 10:05:02
Brad, get a 10,000# gvw trailer. I have a 7,000 that I haul my M on and I can tell you a larger one is what you need. If you ever have to haul your tractor and an implement you will appreciate the difference. I have a tilt-bed trailer so the whole bed tilts, no need for ramps. And make sure to get brakes on both axles.
RickB
07-19-2004 16:46:02
I think you had better scale that M. I pull antique tractors, and there is only one M I can think of that makes the 4500lb class, and he has spoke rears and narrow front. The 7000# trailer I just bought weighs in at a little over 2000#, but that is heavy for that GVW. As suggested, a 10K gvw trailer would be the minimum if I were hauling any M.
Jim.UT
07-19-2004 10:29:01
You have to remember the G in GVW stands for "Gross", meaning the entire weight of the trailer and the load. The most common flat trailers available have either tandem 3500# axles (7000 GVW) or 5000# axles (10000 GVW). The trailer probably weighs in at 1500 lbs all by itself so a 7000 lb GVW only leaves you about 5500 lbs of available load carrying capacity. I prefer to go overkill on things like this, so I would opt for a trailer with 10000 lb GVW. And yes, definitely with brakes.
Makes? It seems like every area has a trailer builder locally. Around here you seem to get a really good trailer for the money from Big Bubba's Trailers in Ogden UT. I have one and I like it a lot. I've seen other builders from MO and KY selling trailers on ebay.
