Tractor Talk Discussion Forum
Protecting tractors while hauling
Jim
07-19-2004 09:01:10
how do you guys protect your restored show tractors while hauling on trailer? seems every time we haul to a show the front and stacks are covered with bugs and little stone chips. looking for some ideas to prevent this. Thanks
al
07-20-2004 06:59:20
 Re: Protecting tractors while hauling in reply to Jim, 07-19-2004 09:01:10
An enclosed car trailer, or a stock trailer if the tractor or implement is small enough to fit.
Matt Smith
07-19-2004 20:09:21
Shrink Wrap
olivertractorgirl
07-19-2004 19:51:45
use tube socks on the stacks, works well
oleblu
07-19-2004 17:00:09
A few guys around here have been using an air dam from the top of a semi-tractor on the front of their trailer. Works good, pulls hard.
TomH
07-19-2004 16:08:24
Take the muffler and air cleaner off. Tape a piece of cloth or something to the front.
TomH
07-19-2004 16:19:20
 Re: Re: Protecting tractors while hauling in reply to TomH, 07-19-2004 16:08:24
And make sure you have something to clean up any glue that might stick, prep sol or whatever disolves the glue, but masking tape shouldn't leave a residue if it's only on for a few hours and not baking in the sun. Or get someone to make a custom cover that you can bungee cord on.
mike
07-19-2004 12:26:46
try backing your tractor on the trailer,it might change the load over the axles so that might not be the answer , just a thought..... .mike
Jim.UT
07-19-2004 10:32:56
A tarp comes to mind, but I don't think that's a good idea because the wind whipping the tarp could be very abrasive on your show quality paint.
How about a V-shaped solid shield on the front of the trailer to deflect all wind, bugs, and small stones? It could be made of plywood or sheetmetal. I'm not sure how to permanently and securely attach it to the trailer. You might also need holes in the bottom to run your tie-downs through.
pg
07-20-2004 03:13:35
 Re: Re: Protecting tractors while hauling in reply to Jim.UT, 07-19-2004 10:32:56
i bought a roll of shipping styrofoam. very soft. cut it to length. cover the fenders and hood and all the tractor. then a soft blanket or 2 over that. then a car cover. strapped very tight to the tractor with about 5 different straps. when i am done the covers do not move. the foam is like a barrier and wont rub the paint off. i only use it when i carry my orchard tractor, because of all the fenders. havent had any stone chips or bugs ruin the paint. it is a pain to do, but it really works well. pg
