Tractor Talk Discussion Forum
Case IH 885 TA
Kraig
07-15-2004 17:14:30
I have a Case International 885 and when you got to low with the TA is is like throwing the tractor in Neutral, you push the clutch in and stop, it takes off again? any help out there?
Bernard le mécano
07-16-2004 18:09:19
 Re: Case IH 885 TA in reply to Kraig, 07-15-2004 17:14:30
Hi Kraig, the T.A is the problem. It have a sprag cluth in it and it is worn. The direct drive side of the T.A is hydrolic( clutch pack actuated by hydrolic pressure) and low side is mecanic( clutch pack actuated by belvil springs and sprag clutch) You may have to do a major job on the T.A of your tractor. Bernard le mécano Québec Canada
Roy in UK
07-17-2004 08:22:10
 Re: Re: Case IH 885 TA in reply to Bernard le mécano, 07-16-2004 18:09:19
Oh thats what causes it, mystery solved I never did know! Many years ago I had a IH 674 do exactly the same thing. The whole tractor was such a heap of junk (one d__ problem after another)that instead of getting it repaired I got rid of it.
casey
07-16-2004 12:07:29
sounds like the mcv pump is loosing it's prime and by stepping in the clutch momentarily it gains it's prime back allowing the tractor to move again.
