Tractor Talk Discussion Forum
3PT Quick Connect
farmer dave
07-15-2004 16:49:06
Farm stores carry this $200 deal they claim makes changing implements on the 3pt easier. Must be people are buying them or they would not carry them. But do they work?
I don't have a loader so I do a lot back there. There's a pallet carrier, the mower, the spreader, the dirt scoop. Really I need a post hole digger. I'm thinking of buiding a 3pt box to haul my fence mending suppies.
Hooking up the bush hog mower is a real pain and takes quite few minutes.
Will that quick connect be slam, bam, thank you ma'am?
Leland
07-17-2004 18:52:03
 Re: 3PT Quick Connect in reply to farmer dave, 07-15-2004 16:49:06
on most farms I have worked on we used a quick hitch ( thats what we call em)on every thing had no problems. GREAT for tillage tools and choppers. Go for it
JT
07-16-2004 08:47:20
Dave
They work nice and I wouldn't try to farm without them. I wouldn't say they are fool proof though. As mentioned earlier some implements won't work with them.
If the implement has a bolt etc holding the hitch together below the top link the QH will give problems. Those links need room to get under their hooks.
You will need adapters for the lower links. Just a bushing usually with a shoulder. The QH's are made for bottom links with Cat 3 size pins and these bushing take care of that.
Unhooking can be a bit of a trick. Just need to adjust the top link until the hitch drops loose. And keep your feet clear!!
Trailing PTO stuff can create problems also. What happens is when turning corners the hitch will hit the driveline shield and beat it up.
All in all if you are working with Cat 2 implements I would suggest getting one, Cat 1 stuff is a little more of a toss up.
HTH
JT
JMS/MN
07-16-2004 17:35:16
 Re: Re: 3PT Quick Connect in reply to JT, 07-16-2004 08:47:20
Quick Hitches are made in various Category sizes. Both of mine were made for Cat Two, and I modified one to fit the Cat Three hitch on the Case 2470 175 hp 4wd. It still fits the Cat Two machines with bushings. Either can be bushed down to Cat One.
JT
07-16-2004 22:10:30
 Re: Re: Re: 3PT Quick Connect in reply to JMS/MN, 07-16-2004 17:35:16
Some implements can be bushed from two to three and work with QH's others not so much. Couple of problems. Some implments have bolts holding the top link hitch together which doesn't allow the QH to get back and under to slide up into position.
You can bush the pins to fit on cat 1 implments but all 4 hitch sizes (0 thru 3) have different width spacings. This doesn't make much difference when hooking arms up but the widths have to be right for QH use.
JM2CW
JT
Mike M
07-16-2004 08:07:26
I found them e-bay #3828150732 I know nothing about them other than what's there to read.
Mike M
07-16-2004 07:53:35
There is a new style out I've seen on e-bay and tractorbynet.com or tractorpoint.com This style goes on your lower arms only one on each arm. Should work better if you have alot of that cat. 1 that is made to different dimensions.
Indydirtfarmer
07-16-2004 04:33:14
Also keep in mind that a quick coupler effectively moves your impliment 3 or 4 inches further back from the tractor, which makes the impliment "heavier" for the 3 point lift, as well as the balance of the tractor. A lot of smaller 3 point impliments don't work well with Quick couplers. They aren't the "cure for the common cold", but they can be very handy. John
JMS/MN
07-15-2004 22:17:24
I have two quick-hitches that I use on three field tractors. Had them for over 25 years. Well worth the money for hooking up plows, mounted field cultivators, row-crop cultivators, etc. May not work with some pto equipment like ph augers, etc. On small machines like a brush hog, snow blower, I don't use them- just the tillage machines. Hooking up large FC, 4,5,6 bottom plows (and keeping them attached in the field) I would not be without them. One trip out of the cab to move the latches and they are field ready.
chuck
07-15-2004 18:51:30
i have a allis wd with an after market 3pt--its a disaster--i bought a quick hitch for it and it has helped tremendously--however be sure that your equipment has a standard width hitch onit--my 3pt mower didnt--had to get rid of that --but all else is good. since most smaller equipment wasnt built really in standard measure ments i have to use an adapter on the top--so its not pickup and go--but it is much easier than it was--good luck
nwb
07-15-2004 18:18:29
I've always used Ford tractors, 8N through 5000. I use both cat. 1 and cat.2 equipment. Quick hitches come in different Cat. sizes. They work great if all your equipment is the same size. By having different cat. size equipment I have never used a quick hitch. I don't know your tractor or equipment,but do your homework before spending $200 on something that you cannot use. For example, my post hole auger does not use a top link. The beam serves as a top link. I've seen others built in this manner. For that type of auger you will need to remove the quick hitch. Hope this helps. LOL
farmer dave
07-15-2004 20:34:31
 Re: Re: 3PT Quick Connect in reply to nwb, 07-15-2004 18:18:29
I'm running a 59 ford 661. I'm dreaming of the Bush Hog Ag model hole digger. IIRC it has a top link. I forgot my blade and bale spike.
Don't have remotes, yet. But I need those to run the NRCS seed drill.
I never thought about the PTO shaft fouling up.
paul
07-16-2004 06:27:04
 Re: Re: Re: 3PT Quick Connect in reply to farmer dave, 07-15-2004 20:34:31
PHD have their own top link, not a removable one like most other implements. I think every phd I've seen would not work with a quick hitch, but i haven't seen everything. :)
Measure the width between pins on all your implements, must be the same. Measure the height between the lower pins & the top link pin - must be the same on all implements. Check that there is room around each lower pin for the bigger J-hook of the quick hitch - some implements are too close on an angle iron or the like. Top pins frequently give trouble on this - they have some obstruction that doesn't allow the bigger hook to engage from the quick hitch.
A few pto items might have too short of a shaft now, with the 2-3" added to the connection.
A heavy load, like your bale spear, will probably make the front end too light, or the 3pt won't lift the load any more because it's moved back 3".
I doubt the post hole digger will work with a quick hitch.
Now, _if_ you get all that worked out & set up & all matching, then a quick hitch is a great help! :)
So, do the homework.
I don't bother with the cat 1 stuff as that is pretty easy to hook up, but as someone else said, for my bigger tractor I just got one this year, switching between the plow, 15 row planter, row cultivator, and field cultivator was killing me, now back up, lift, & ready to go. :)
--->Paul
Allan in NE
07-15-2004 17:46:38
Dave,
Wham and Bham. Except for the darned PTO and any hydraulics you are using.
Allan
Ron
07-15-2004 16:53:01
I use them on my rotary cutter and would not be without them. Yep, they work just like they say.
