Tractor Talk Discussion Forum
30 Massey-Harris has leaky transmission seal
R. Jacobs
07-13-2004 19:44:51
I am looking for some info on what kind of job it is to replace the front seal. Any info would be appreciated. Thanks
Dave_Id
07-14-2004 13:56:20
 Re: 30 Massey-Harris has leaky transmission seal in reply to R. Jacobs, 07-13-2004 19:44:51
All of what msb said, but I do believe you can slide the engine forward out of the way. I don't think you can remove with a seal pick, because if it's like a 101 Sr, the seal is on the inside of the casting. My biggest job was getting my sprocket off. It took four hours of beating with hammer and punch and using heat, fortunely, after it was all cleaned up, it reassembles very easily.
msb
07-14-2004 13:20:17
Think you have to remove the hood and gas tank.Then uncouple the drive shaft.Then remove the bell housing.You might have to block up the rear of the engine first.You should then be able to remove the drive coupling and then remove the front bearing quill(Be careful there could be shims behind the quill(not sure about that)That is if you can't just remove the seal without pulling the quill.Sometimes you can use a sharp tool to penetrate the seal and pull it out trhat way.A seal puller works good for that.Be very careful when replacing the seal that sharp edges on the shaft don't cut the seal.I would use a fine file or emery cloth on any edges first then use gobs of grease on the shaft.Got to replace one myself on a Massey 44-6 that I am restoring.
